This command shows the run-time or active values for all CA Vtape parmlib attributes. At startup and after a REFRESH console command, all or part of the parmlib attributes are loaded into the Local VCAT. This command displays the loaded values.
SVTn Display Parmlib [,{Short|Medium|Long}] [,{Hardcopy|Console}]
Displays the active attributes defined in the Parmlib Directory, Startup Options, Dynamic Options, Volume Pool Definitions*, PeerToPeer Options*, and PeerToPeer Remotes*. Items marked with an asterisk (*) are only displayed if activated.
SHORT is the default value.
Displays Short plus the active attributes defined in the Virtual Device List, Startup Commands, Shutdown Commands, and Group Definitions.
Displays Medium plus the active attributes defined in Data Set Filters.
The following are the Output options:
Directs the output to the system log and the SVTS JOBLOG. This is the default output option.
Directs the command response to the system log, SVTS JOBLOG, and the operator console.
Note: By adding the SVTn D P,L console command to the Startup Commands section in the parmlib, the complete set of active parmlib attributes can be automatically documented in the SVTS JOBLOG during CA Vtape initialization.
