Quick Migration assumes that relatively few CA Vtape Subsystems are involved and that sufficient additional DASD space is available to create a dynamic cache DASD pool the same size as the static cache DASD pool. This allows all of the subsystems to be converted at the same time.
To perform a Quick Migration
Note: Until Step 6 is completed, mounts of existing Virtual Volumes will be performed in the mode that the volume was originally created in. Virtual Volumes created before changing to dynamic will be read and recalled in the static cache.
Note: If any Virtual Volumes created in static mode cannot be Externalized, take the necessary actions to copy any needed application data sets to DASD or physical tape and scratch the Virtual Volumes.
RESET_CACHETYPE=DYNAMIC
Each static Virtual Volume Entry in the Global VCAT will be converted to dynamic. It takes approximately 18 minutes to convert 20,000 active Virtual Volumes when the subsystems are under a light workload. Executing the utility when the subsystems are under a heavy workload will cause delays due to competition for the Global VCAT and BSDS.
The program will produce an error report for any unconverted Virtual Volumes. These are typically Virtual Volumes that were not Externalized or were active or mounted when the utility was executed.
Note: You can repeat Steps 5 and 6 as often as necessary in order to convert all of the existing static Virtual Volumes.
LDS_DELETE
This will delete all static cache LDSs from both DASD and the CA Vtape Global VCAT.
Note: For more information about the command and its parameters, see the chapter “SVTSUTIL Batch Commands.”
All your complexes are converted.
