Previous Topic: Cache MonitorNext Topic: Volume Count
Virtual Volume Compression
Virtual Volume compression lets you simulate Improved Data Recording Capability (IDRC) for CA Vtape Virtual Volumes by compressing the data as soon as the Virtual Device Engine receives it from the application and prior to writing it to a cache LDS.
There are multiple advantages to compression:
Note: The additional CPU overhead required as well as the compression rate achieved is a function of the data. While it was common during our own benchmarks to see 2-to-1 compression rates, you may not get the same amount of compression.
The CA Vtape compression routines use a combination of techniques including the run length limited (RLL) processing facility, the hardware compression facility as described in the IBM publication Enterprise Systems Architecture/390 Data Compression, SA22-7208, and LZ compression through hardware instructions, software instructions, or both. When Virtual Volume Compression is enabled, the Virtual Device Engine periodically analyzes the data written to a Virtual Volume to dynamically select the most efficient compression technique.
