Previous Topic: Recovery Error MessagesNext Topic: SCRATCH
RESET_CACHETYPE
This command is used when running the SVTSUTIL program to convert the Virtual Volume Entries (VVEs) in the Global VCAT from Static to Dynamic Cache Management or vice versa. Only Virtual Volumes that have been Externalized can be converted. Virtual Volumes that have not been Externalized will receive an error message and will not be converted.
This command should only be used as part of the cache management conversion procedures.
Note: For more information, see the appendix “Conversion Procedures.”
Syntax
RESET_CACHETYPE={DYNAMIC | STATIC}
