Previous Topic: LDS_DELETENext Topic: LDS_INITIALIZE=
LDS_INELIGIBLE
This command flags one static cache LDS as ineligible for allocation. Ineligible LDSs are counted as part of the DASD buffer, but bypassed during LDS allocation. You can use this command to temporarily remove one or more LDSs from processing. It is also internally used by CA Vtape when errors are detected while LDSs are being allocated or accessed.
This command should only be used when no virtual mount activity is occurring and after running the SVTSUTIL program with the LIST=CACHE command to verify that the LDS does not currently contain a Virtual Volume that needs to be Externalized.
Syntax
LDS_INELIGIBLE=lds.cluster.name
