The RECYCLE utility accepts various types of commands to control input selection and the output method during the execution.
Example of Group-based RECYCLE
SET MODE(SIM) SET LINECOUNT(60) SET MOUNTTIMEOUT(5) SET CART3480(00400),CART3490(00800),CART3590(10000) RECYCLE GROUP(21),SUBGROUP(*),PERCENT(50),SOURCE(PRI),TARGET(BOTH)
Example of VOLSER-based RECYCLE
SET MODE(SIM) SET LINECOUNT(60) SET CART3480(00400),CART3490(00800),CART3590(10000) RECYCLE PHYSICAL(123456),TARGET(BOTH)
The following syntax conventions are used throughout this chapter:
A | B
A single bar is used to separate multiple values for the same parameter.
A|B|C
Underlines are used to indicate the default value of a parameter.
nn
Italics text represents a variable, for example Group=nn where nn is a number.
AAaaa
Uppercase characters indicate abbreviations or the minimum number of characters that must be entered to identify the parameter or value.
