Use the following procedure to revert back to static mode.
To revert back to static mode
Note: If after converting to dynamic cache you also converted to 2000 MB Virtual Volumes, you cannot convert back to 400 or 800 MB Virtual Volumes. This will cause any 2000 MB Virtual Volumes to be lost. Execute the Define option of the CA Vtape ISPF Customization Process to generate a new SUTPARMS member with a Virtual Volume Size of 2000 MB and to generate the DEFLDSxx and LDSADDxx jobs to define, initialize, and add 200 MB cache LDSs to the Global VCAT.
First, run GRRJCL to ensure that all Unexternalized Virtual Volumes are queued for Externalization. Then use the SVTn Display Group and SVTn SET BACKstore commands to ensure that dynamic Virtual Volumes are queued and being Externalized.
RESET_CACHETYPE=STATIC
This will convert the existing dynamic Virtual Volumes to static mode. You may need to do this step more than once if the report shows errors.
