Previous Topic: REFRESH=USSNext Topic: RESTART CMDMGR
RESTART BACKSTORE
This command is used to gracefully stop and release all acquired Backstore resources.
When this command is issued, CA Vtape does the following:
The Backstore Engine might not respond to a restart command if it is waiting for communication from the operating system or a Backstore Tape Device. In these situations, the Backstore Engine can be unconditionally interrupted by reissuing the Restart command with the optional Cancel parameter, that is, SVTn Restart Backstore,Cancel.
Syntax
SVTn Restart Backstore [,Cancel]
Example of information displayed by the RESTART BACKSTORE command
SVT1 R B SVT1X0101I Command Scheduled in SVTS SVT1X0100I Command Complete  SVT1A0001I SVT1PT   Stopping                                               CTS014 IEF234E K 0752,508039,PVT,SVTSAS,SVT1PT IEF234E K 0752,508039,PVT,SVTSAS,SVT1PT IEF170I 1 SVTSAS CAJR250I STEPNAME STEP PGM= CCODE EST-COST IEF170I 1 SVTSAS CAJR251I SVT1PT 1 SVTSAS 0000 $35.54 IEF404I SVTSAS - ENDED - TIME=15.10.01 IEF170I 1 SVTSAS CAJR252I JOB ENDED. TOTAL EST-COST $35.54 $HASP395 SVTSAS ENDED $HASP100 SVTSAS ON STCINRDR $HASP373 SVTSAS STARTED ACF9CCCD USERID SVTSAS IS ASSIGNED TO THIS JOB - SVTSAS IEF403I SVTSAS - STARTED - TIME=15.10.01 SVT1A0000I SVT1PT Ready
Important! If the Cancel option is used when Externalization tasks are active, the Backstore Tapes that were mounted should be released from further processing by issuing the SVTn SET BACKSTORE=EXCLVOL,VOLser=volser console command when the Backstore Engine address space is active again. This is necessary because the tasks were prevented from saving the last file sequence number used by the cancel. If these physical tapes are remounted by the Backstore Engine, they must be read sequentially to determine the appropriate file sequence number to use. This could result in a significant delay for Externalization as each task started reads its PRIMARY tape sequentially and then, if duplexing is active, repeats the action for its DUPLEX tape.
