This command can be used to generate a report of Virtual Volumes queued for Externalization.
LIST=GRR [,VVE_WRITE | ,REMOTE]
Sample JCL can be found in HLQ.CCUUJCL(LISTGRR).
VVE_WRITE and REMOTE are optional parameters. They are primarily intended for internal use only.
VVE_WRITE causes the program to generate VVE_WRITE= control cards for Virtual Volumes missing from the Externalization Queue that require Backstore processing. These generated control cards are used by the GRRJCL1 batch job to requeue Virtual Volumes that are missing from the Externalization Queue that were transmitted to this subsystem with the ExchangeMetaDataOnly=D attribute setting.
REMOTE causes the program to generate a control card list of Virtual Volumes queued for Externalization that were transmitted to this subsystem with the ExchangeMetaDataOnly=D attribute setting. This list is used by the DEFERXMT batch job to issue transmission requests for the Virtual Volume data to the local, owning subsystems.
