If the CA Vtape P2P Option is active, console commands can be executed on a remote system. If the command is a display command, that display will appear on the console of the target remote system and also in the system log of the issuing system.
The syntax to issue a command on a remote system is as follows:
SVTn.Sxnn command or SVTn/Sxnn command
Where:
Is the system which issues the command
Is the suffix ID of the target SVTS remote console. The remote consoles definitions can be found in the VTP2PRMT parmlib member.
Is the CA Vtape console command.
For example, if the local CA Vtape subsystem is SVT3 and the console suffix ID of the remote system is S261, then the syntax would be:
SVT3.S261 command
