Previous Topic: DISPLAY UNITNext Topic: DUMP
DISPLAY USS
This command displays UNIX mount point information used by USS Backstore. By default, the command normally displays each mount point followed by only the directories within those mount points contain files.
Syntax
SVTn Display USS [,ALL|,DIR|,MNT]
ALL
Display all directories within each mount point.
DIR
Display only directories.
MNT
Display only mount point information.
Example of information displayed by the DISPLAY USS command
SVT4 D USS                                                               SVT4X2105I Unix File System Information                              Data Set   OMVSUSR.LEELA02                                               Type       HFS,R/W,Active                                                MountPoint /a/leela02                                                    Statistics           Capacity(gb) Use%                                   InUse                         .00   0%                                   Free                          .16 100%                                   Total                         .16                                        Directories         Allocated(gb) Use%    #Files   FileSize(gb)          ..                            .00   0%         2            .00          .                             .00   0%         1            .00          Total                         .00   0%         3            .00          Data Set   VTAPEQA.TRIPLEX                                               Type       NFS,R/W,Active                                                MountPoint /a/leela02/svts/FF43F397/triplex                              Parms      10.130.42.54:"/nas/vtapeqa/fds/QA",hard,llock(y),proto(tcp),             xlat(N),attrcaching(y),datacaching(y),delaywrite(32),readahe             ad(8)                                                         Statistics           Capacity(gb) Use% InUse                        4.12   1%                          Free                       389.22  99%                          Total                      393.34                               Directories         Allocated(gb) Use%    #Files   FileSize(gb) ./triplex                     .00   0%        35            .00 ./triplex/group31             .00   0%        23            .95 ./triplex/group32             .00   0%         5            .51 ./triplex/group33             .00   0%         2            .14 ./triplex/group61             .20   0%        98          26.34 ./triplex/group63             .23   0%       107          30.24 ./triplex/volumes             .00   0%       235            .00 Total                         .43   0%       505          58.18 SVT4X0100I Command Complete
