The BSDS and the Global VCAT maintain similar information. Either data set can be recovered from the other. They should be placed on separate DASD volumes, preferably in separate DASD subsystems so that they do not end up on the same physical HDA. This ensures that a single hardware failure does not damage both data sets.
The ability to recover the BSDS and the Global VCAT is an important feature of CA Vtape. We recommend that you do regular backups of the BSDS. In the unlikely event that both the BSDS and the Global VCAT are accidentally deleted or destroyed, you can restore the BSDS from a backup tape and then use it to recover the Global VCAT.
To recover the Global VCAT from the BSDS
RECOVER=GLOBAL,PREFIX=prefix,NOINIT [,DROP_INELIGIBLE] [,SCRATCH]
RECOVER=GLOBAL,PREFIX=prefix,DROP_INELIGIBLE [,NOINIT] [,SCRATCH]
If these LDSs are not dropped, they will be added back to the Global VCAT and to the cache totals. If these LDSs will not be created or corrected, dropping them will ensure that the DASD buffer totals are not artificially inflated, which affects the parmlib cache percentage parameters and the displayed cache subtotals. Dropping them will also ensure that the LIST=CACHE and Reclaim jobs will not try to process and report on them.
If you use Dynamic Cache Management, the DROP_INELIGIBLE command has no affect on the recovery.
Note: For additional information about the RECOVER=GLOBAL command, see the chapter "SVTSUTIL Batch Commands."
If you are using Dynamic Cache Management, this step is not needed.
