Previous Topic: LIST=BACKSTORENext Topic: LIST=MODULE
LIST=CACHE
This command is used when running the SVTSUTIL program to determine whether or not any DASD buffer LDSs have become unchained or lost. LDSs should be chained to one of the following locations:
The report generated by this command details where the LDSs are chained and whether or not they are unchained, along with whether or not a Virtual Volume associated with an LDS needs to be Externalized.
Syntax
LIST=CACHE [,NOCATALOG|NOCATALOG,WTOD]
The optional NOCATALOG,WTOD parameter is used by the GRRJCL utility to suppress the catalog locates for the DASD buffer LDSs and to access the Write Time Of Day (WTOD) field in the Virtual Volume Entry in the Global VCAT. Eliminating the catalog locate reduces the GRRJCL utility runtime. The WTOD output consists of the date in Julian format and the time of day printed side-by-side in 16-byte fields.
Sample JCL can be found in HLQ.CCUUJCL(LISTCACH).
Note: If this diagnostic tool is run during periods of high virtual tape activity, it can impact virtual tape response times.
The LDS chains are dynamic. During mount or Backstore activity, these chains are being continuously updated. To determine if an LDS is correctly chained, this diagnostic tool must serialize the Global VCAT to prevent updates. The serialization is maintained for a short period and then released to allow other processes to update the Global VCAT. After a short wait, the Global VCAT is again serialized. This pattern is repeated until all LDSs have been evaluated.
If the report indicates that an LDS has become unchained or lost, you can recover it by using the SVTSUTIL RECLAIM command. Sample JCL can be found in HLQ.CCUUJCL(RECLAIM).
Sample output created from using the LIST=CACHE parameter
                 CA Vtape r11.5        S V T S U T I L     -    CA11.SVT2        - Thu JUN 28, 2007  19:02:07  ---------------------------------- Utility Control Statement(s) & Report Log -------------------------------  SVTSU0171I LIST=CACHE  SVTSU1661I Accessing SVTS to identify GLOBAL VCAT and Local VCAT datasets             Reason: GLOBAL DDName statement not defined                     VCAT   DDName statement not defined  List Cache Log                                              2007.179  19:02:07  *Inelig* - Allocation of the LDS failed  Queued - Queued for externalization  *MustReq - Must be manually requeued  n/a - in Virtual field indicates LDS Cellpool status is UNUSED  Lost1 - The LDS Cellpool status is allocated, but the LDS VVE vol does not exist  Lost2 - The LDS Cellpool status is allocated, but the VVE vol has been scratched  Lost3 - The LDS Cellpool status is allocated, but the LDS is not in the associated VVE vol LDSTABLE  Lost types above - Generally the Reclaim utility will make these LDS usable again                                            Dynamically Allocated Cache Data Sets  ------------------------------------------------------------------------------------------------------------------------  Cache     Linear                                        Virtual   Externalized  Volser    Dataset                                       Volser    Status       #mb.InUse #mb.Alloc CacheExpDt CacheExpTm  ------------------------------------------------------------------------------------------------------------------------  VTP11H    SVTS120.VT3.VVE.V108006.MM.CACHE              108006                        12        13   07/19/07      20:22  LOANV1    SVTS120.VT3.VVE.V108008.MM.CACHE              108008                        16        17   07/18/07      19:51  LOANV3    SVTS120.VT3.VVE.V108009.MM.CACHE              108009                        16        17   07/18/07      19:51  LOANV6    SVTS120.VT3.VVE.V108010.MM.CACHE              108010                        16        17   07/18/07      19:51  LOANV3    SVTS120.VT3.VVE.V108090.MM.CACHE              108090                         8         9   07/18/07      19:51  VTP11A    SVTS120.VT3.VVE.V108091.MM.CACHE              108091                         8         9   07/18/07      19:51  VTP11D    SVTS120.VT3.VVE.V108092.MM.CACHE              108092                         8         9   07/18/07      19:51  LOANV5    SVTS120.VT3.VVE.V109100.MM.CACHE              109100                       432       433   07/18/07      18:56                                                           Pre-allocated Cache Data Sets  ------------------------------------------------------------------------------------------------------------  Cache     Linear                                            Virtual   Externalized  Volser    Dataset                                           Volser    Status  ------------------------------------------------------------------------------------------------------------  SMD062    QAPROD.VVE.LDS00000                               100708  SMD062    QAPROD.VVE.LDS00002                               100751  SMD043    QAPROD.VVE.LDS00003                               100722  SMD066    QAPROD.VVE.LDS00004                                n/a  SMD056    QAPROD.VVE.LDS00005                               100724  SMD065    QAPROD.VVE.LDS00006                               100724  SMD065    QAPROD.VVE.LDS00007                               100721    CA11,3  SMD031    QAPROD.VVE.LDS00008                               100721    CA11,3  SMD004    QAPROD.VVE.LDS00009                               100726  SMD045    QAPROD.VVE.LDS00010                               100725
 SMD046    QAPROD.VVE.LDS00011                               100692  SMD061    QAPROD.VVE.LDS00012                               100692  SMD054    QAPROD.VVE.LDS00013                               100692  SMD052    QAPROD.VVE.LDS00014                               100724  SMD065    QAPROD.VVE.LDS00015                               100721  SMD043    QAPROD.VVE.LDS00016                               100767     Queued  SMD058    QAPROD.VVE.LDS00017                               100725              SMD051    QAPROD.VVE.LDS00018                               100732              SMD060    QAPROD.VVE.LDS00019                               100767     Queued   SMD052    QAPROD.VVE.LDS00020                               100767     Queued   SVTSU0172I LIST=CACHE                                               SVTSUT60, RC=     0  SVTSU0173I Number of commands processed:        1  SVTSU0174I Highest condition code:              0
The Cache Volser on the far left is the DASD volume the LDS resides on. LDS00000 resides on DASD volume SMD054 and currently contains part or all of Virtual Volume 102619.
The following is a list of Externalized Statuses, which indicate the current Externalization status of the Virtual Volume:
Blank
Indicates that the Virtual Volume has been Externalized.
CrashProt
VVE does not have a write time of day. The ending tape mark may be missing. Check the tape management system to determine if the Virtual Volume is active with data blocks written to it or in scratch status. If the Virtual Volume is in scratch status, the next run of the Scratch Synchronization Job should scratch the Virtual Volume with the Global VCAT.
*Inelig*
Indicates the LDS has been marked ineligible. Verify that the LDS has been properly defined and then execute the SVTSUTIL batch command LDS_ADD.
*MustReq
Indicates that the Virtual Volume is still in the DASD buffer. The volume is not queued and should be manually requeued by using the SVTSUTIL batch command VVE_WRITE or the batch job GRRJCL.
Queued
Indicates that the Virtual Volume is still in the DASD buffer. The volume is queued and waiting to be Externalized.
SYSID,n
Indicates the Virtual Volume has been reserved on the displayed system by subsystem n. If the Virtual Volume is not in use execute the SVTSUTIL batch command VVE_FREE.
If n/a appears in the Virtual Volser column, then the associated LDS does not contain a Virtual Volume. This is an LDS that was never allocated to any Virtual Volume or never freed for reuse by running RECLAIM.
