Previous Topic: Diagnostic ToolsNext Topic: Diagnostic Trace
List of Tools
TSS LIST
Lists ACID information including that contained in attached profiles. It can also list global (ALL) authorizations related to the accessed resource. Refer to the Command Functions Guide.
TSS WHOHAS
Lists the ACIDs which have access to the resource specified in the command. Refer to the Command Functions Guide.
TSSUTIL program
Used to obtain event reports. Refer to the Reporting Guide.
TSS WHOAMI
Describes a logged on user’s security environment and important controls such as bypass attributes, log and message display options, and user’s mode. Useful for “on-the-spot” debugging. Refer to the Command Functions Guide.
MODE
The mode of the actual event, not always the user’s or facility’s mode. You must know the actual mode, be it facility, user, or event level. The only sure way of knowing the mode of a security event is through a trace. Refer to the Control Options Guide.
Authorization Algorithm
Basic understanding of the algorithm is mandatory for definition of proper authorizations. Refer to the General Concepts Guide.
AUTH control option
Incorrect setting or changing of AUTH dramatically affects whether CA Top Secret grants access to a resource. Refer to the Control Options Guide.
LOG control option
LOG and FACILITY(LOG=) control CA Top Secret violation recording and message display. Refer to the Control Options Guide.
Message Algorithm
Explains when and why messages are displayed or suppressed. Appendix C describes the algorithm.
MSG control option
Controls message characteristics, such as when they are to be suppressed. Refer to the Control Options Guide for details.
TRACE
The diagnostic trace can be employed to provide event-related details that cannot be uncovered by other tools. Appendix B explains how to interpret trace information. See TRACE in the ADD/REMOVE chapter of the Command Functions Guide and SECTRACE or FACILITY in the Control Options Guide for instructions on how to apply the trace.
STATUS control option
Status of various control options and understanding of how they relate to or affect the behavior of Trust CA Top Secret Security. Refer to the Control Options Guide for details.
FACILITY control option
Attributes and status of facility controls. Refer to the Control Options Guide for details.
DRC control option
Controls or displays violation attributes, especially if your site has changed the effect of some violations. See DRC in the Control Options Guide, and DRC in the Messages and Codes Guide.
DUMP control option
Generates internal control block dump. Appendix D documents how to interpret the output. See also DUMP in the Control Options Guide.
CAIMAINT
To obtain a maintenance level, and optional and special zap status.
