To set a SAFTRACE to show all RACROUTE calls with resulting reason codes for machine SFSSERV, enter the following:
TSS MODI(SAFTRACE(SET,ID=TRACE1,TRACE=AFTER,VMUSERID=SFSSERV))
Note: The results of a SAFTRACE(DISPLAY,...) are returned to the issuer of the command. If DEST= is used, the actual traces, as they occur, will go to the CA Top Secret service machine console and the userID specified in the DEST= parameter. If DEST= is not specified, the trace info will only go to the service machine console. To see those traces as they occur you must set active the secondary console support for the service machine.
Copyright © 2009 CA.
