Prints a cross reference of all ARLB block keys and the actual ARLBs in the block. ALLOC also verifies the number of ARLBs against what is in the header block map.
This routine assumes that if an ARLB is allocated, it should have something in it. Exceptions exist if an ARLB is chained and the first byte was used to add an x'00' to end an XE. This makes the key appear to be wrong because the key is allocated but the ARLB is empty. These cases can be resolved using the ACIDCHAN function.
Copyright © 2009 CA.
