Previous Topic: TSSCMDOPTION—Command DefaultsNext Topic: UNIXOPTS—Special Options for USS
TSSCMDOPTION Valid Options
ADMINBY|NOADMBY
ADMINBY
When enabled, CA Top Secret records and lists information in ACID security records to indicate the:
  • Administrative ACID who performed the change
  • Date, time, and system SMFID where the change was performed
ADMINBY data is stored each time an ACID is created, a FACILITY is added, or a resource is permitted.
When ADMINBY is turned on:
NOADMNBY
(Default) Suppresses the administrative date—time stamp storage and LIST display.
TERSE|VERBOSE|ENHANCED
VERBOSE
(Default) Displays all the related hierarchy ACIDs information beyond the owning ACIDs And the full NAME attributes.
TERSE
Does not display the ADMINBY information, ACID hierarchy information beyond the owning ACID, or the full NAME attribute. This saves significant overhead in security file access and in CPU time expended.
ENHANCED
Displays all information included in VERBOSE plus:
  • MASK attribute information on a PERMIT
  • ACID type for target acid in an ADMIN SCOPE listing
  • RDT attribute will display PIE for Prefixed resources
