Previous Topic: Example: TEXTTSS control optionNext Topic: Example: TIMELOCK control option
TIMELOCK—Lock Interval
Valid on z/OS.
Use the TIMELOCK control option to control the interval at which CA Top Secret will attempt to obtain the Security File lock or an acid enqueue.
All entry methods are accepted.
TIMELOCK(nnn1,nnn2,nnn3,nnn4)
The operand values are specified as whole numbers with up to four digits in each.
nnn1
The number of .01 second units between tries for the lock.
nnn2
The number of retries for the lock.
nnn3
The number of retries for an acid enqueue.
nnn4
The number of retries for the lock after it is determined that a BACKUP is in progress.
Default: (25,64,128,1200). The default value specifies a retry for the lock every 25 hundredths of a second (every quarter second), and that the TSS9123A message is issued after 64 tries. Thus, it takes 16 seconds of trying for the lock before the TSS9123A message is issued. When trying to obtain an acid enqueue, the third parameter (128) is used. The TSS9122I message is issued after the first 128 tries (32 seconds), and the ENQ variation of the TSS9123A message after another 128 tries (32 seconds). If a backup is in progress on another system, the TSS9125I message is issued when the first 16 seconds (from the second parameter) expires, and the TSS9123A message is issued after an additional 1200 tries, or 300 seconds, based on the fourth parameter.
