Previous Topic: PagingNext Topic: Examples: SYNCH control option
SYNCH—Synchronize Tables
Valid on z/OS and z/VM.
Use the SYNCH control option to request the immediate synchronization of global in‑memory tables (ALL, AUDIT, RDT, STC) with the Security File.
SYNCH is usually only required for processors in global DORMANT mode.
This control option uses the O/S or TSS MODIFY command entry methods
SYNCH
