Previous Topic: SHRPROF—Shared Profile TableNext Topic: Example: SHUTDOWN
SHUTDOWN—Shutdown Server
Valid on z/VM.
Use the SHUTDOWN control option to bring down the server machine.
This provides for a clean way to bring down the CA Top Secret server machine. If any other method is used, Security File corruption can result. Any new security requests are subject to DOWN options.
This control option uses the MODIFY entry method.
SHUTDOWN[,EOD]
EOD
Causes the server machine to issue a CP shutdown after the server machine has completed its own termination.
To use the EOD function, the entire option must be in single quotes:
TSS MODIFY('SHUTDOWN,EOD')
