Previous Topic: SHRFILE—Share FilesNext Topic: SHRPROF—Shared Profile Table
Examples: SHRFILE control option
This example indicates that all of the files used by CA Top Secret is shared among other operating systems and/or CPUs.
SHRFILE(YES)
Make the following entry if you want to share the file between CA Top Secret 5.2 systems only.
SHRFILE(YES,AINDXPER)
This example indicates that file is standalone but performance feature is not on.
SHRFILE(NO)
Make the following entry if the performance feature should be on and the file is a standalone.
SHRFILE(NO,AINDXPER)
You cannot issue a MODIFY with SHRFILE(YES) to turn off just the AINDXPER suboption if SHRFILE(NO)AINDXPER was originally issued. For example.
SHRFILE(NO)
