Previous Topic: Example: RECFILE Control OptionNext Topic: REFRESH—Reinitialize CA—CAF Modules into CSA
RECOVER—Record Changes in Recovery File
Valid on z/OS and z/VM.
Use the RECOVER control option to indicate whether CA Top Secret records changes made to the Security Database onto the Recovery File. Changes include those made automatically by CA Top Secret (automatic volume ownerships, password changes) and those made by security administrators via the TSS command.
If this option is omitted at CA Top Secret startup, RECOVER(ON) is in effect if the RECFILE DD‑statement is in the CA Top Secret started task.
RECOVER(ON|OFF)
ON
(Default—As long as RECFILE DD‑statement is in CA Top Secret started task procedure) Activates the Recovery File. Indicates that changes made to the security database is recorded in the Recovery File.
OFF
Deactivates the Recovery File. Turn Recovery OFF when running the TSSRECVR utility to prevent double recording of changes.
