Previous Topic: Examples: RDT2BYTE control optionNext Topic: Example: RECFILE Control Option
RECFILE—Identify Recovery File
Valid on z/VM.
Use the RECFILE control option to identify the OS data set name of the Recovery File. Use the data set must reside on the DASD volume or minidisk at virtual address X'400' of the server machine.
This control option uses the Parameter File entry method.
RECFILE(dataset‑name)
datasetname
The OS data set name for the Recovery File.
Default: The OS data set name created by the utility TSSMAINT (CAI.TOP.SECRET.RECOVERY.FILE).
