Previous Topic: Examples: PPCHAR control optionNext Topic: Example: Products control option
PRODUCTS—Special Products
Valid on z/OS.
Use the PRODUCTS control option to list special products, if any, that are installed on the system.
All entry methods are accepted.
PRODUCTS(name,name...)
TSO/E
(Default) Indicates that TSO/E is being used instead of TSO. This is the default.
ACF/2
Indicates that CA‑ACF2® is temporarily active, awaiting conversion to CA Top Secret.
CA‑Tape
Indicates that CA‑Tape is active for processing tape volumes at the data set name level.
TSO
Indicates use of TSO.
NONE
Resets the option.
