Previous Topic: Examples: NPWRTHRESH control optionNext Topic: OMVSTABS—UID and GID Tables
OMVSGRP—OMVSGRP Segment
Valid on z/OS.
Use the OMVSGRP control option to specify the acid used to provide the OMVSGRP segment for an extract for any group that does not have an OMVSGRP segment.
Note: LNXENTS should be added to the acid specified in the OMVSGRP control option using the ALL facility. This LNXENTS entry will act as a default for any groups who do not have a LNXENTS specified on their acid.
This control option will also be the value used as DFLTGRP for an extract for any user who does not have the field DFLTGRP defined. It is not used as a default group for such a user at signon time, but only on an extract.
All entry methods are accepted.
OMVSGRP(acid)
acid
The acid should be a type 'GROUP' acid, and should be given the field GID.
Default: The field DFLTGRP from the acid specified in the OMVSGRP control option.
