Previous Topic: Examples: NEWPW control optionNext Topic: Examples: NJEUSR control option
NJEUSR—NJE Store and Forward Nodes ACID
Valid on z/OS.
Use the NJEUSR control option to define a default ACID to be used for NJE Store‑and‑Forward nodes where no other userid can be identified. This control option is used to specify the userid when building a default token in response to a verify SESSION=TKNUNKWN request.
Notes:
This control option uses the Parameter File and TSS MODIFY Command entry methods.
NJEUSR(acidname)
acidname
The ACID that is used in the VERIFYX call.
