Previous Topic: Examples: MSUSPEND control optionNext Topic: NEWPW—Password Alterations
NEWPHRASE—Password Phrase Rules
Valid on z/OS and z/VM.
Use the NEWPHRASE control option to specify the controls for password phrases.
Important! The alpha count minimum (MA), digit count minimum (MN), and special character count minimum (SC) must not exceed the total phrase character maximum (MAX). This constraint is evaluated sequentially from left to right each time any of these variables is changed.
TSS MODIFY NEWPHRASE([MA=nn],[MN=nn],[ID],[MAX=nnn],[MIN=nn],
                     [MINDAYS=nn],[NR=nn],[NU],[SC=nn],[WARN=nn])
MA=nn
Specifies the minimum number of alpha characters.
Range: 0 to 32
Default: 0
MN=
Specifies the minimum number of numeric characters.
Range: 9 to 32
Default: 9
ID
Prevents users from specifying a new password phrase that contains their ACID name.
MAX=nnn
Specifies the maximum length of a password phrase.
Range: 14 to 100
Default: 100
MIN=nn
Specifies the minimum length of a password phrase.
Range: 9 to 32
Default: 9
MINDAYS=
Specifies the number of days after a password phrase is changed before the user is allowed to change the password phrase again.
Range: 0 to 99
Default: 0
NR=
Specifies the number of pairs of repeating characters in a new password phrase.
Range: 0 to 5
Default: 0
NU
Specifies that an ACID TYPE(USER) cannot change their own password phrase.
SC=nn
Specifies the minimum number of characters that the new password phrase must have from the PPSCHAR list. If no PPSCHAR set is available no action is taken.
Range: 0 to 32
Default: 0
WARN=nn
Specifies the warning days given that a password or ACID is about to expire.
Range: 0 to 99
Default: 3
