Previous Topic: Example: LDAPNODE control optionNext Topic: Examples: LDS control option
LDS—LDAP Outbound Processing
Valid on z/OS.
Use the LDS control option to enable LDAP outward data sync processing for the TSS region.
LDAP nodes are defined to the TSS database through NDT table entries. Each node entry controls what update events are sent to the LDAP server, and how ACID fields are mapped to LDAP directory attribute fields.
The LDS control option enabled/disables processing in a TSS region. On the ACID level, the LDS command adds or removes the LDS attribute to or from an ACID record, the LDAPNODE command defines LDAP nodes to the TSS database as NDT node elements, and the LDAPDEST command adds, removes, or replaces nodes to the LDAP node list of an ACID record. For information, see the Command Functions Guide.
All entry methods are accepted.
LDS(ON|OFF)
ON
Enable LDAP outbound processing for the TSS region.
OFF
(Default) Disable LDAP outbound processing for the TSS region.
