Valid on z/OS 1.8 and below.
Use the KERBLVL control option to specify the highest available encryption level available for Kerberos certificates. This varies according to the level of z/OS and the Kerberos configuration file parameters at your site. KERBLVL is is valid on z/OS 1.8 and below only. For z/OS 1.9 and above, all encryption types are supported.
For information, see the IBM Secure Way Network Authentication Service Administration Guide.
All entry methods are accepted.
KERBLVL(0|1)
(Default) Indicates that only DES encryption is available.
Indicates that DES, DES3, and DESD encryption are available.
