Valid on z/OS.
Use the JESNODE control option to indicate the name by which JES2 knows the local node. This allows jobs and SYSOUT where the submitting node is the local node to be treated differently from NJE jobs and SYSOUT originating from other nodes.
JESNODE(nodename)
Indicates the name of the local JES2 node.
If JESNODE was changed using a TSS MODIFY command, the changes made remain in effect even if CA Top Secret is restarted. Most control options revert to their default settings, the exceptions are DUFPGM, JESNODE, and NJEUSR.
