Valid on z/OS.
Use the IMS control option to set six different suboptions for IMS security processing.
All entry methods are accepted.
IMS([NO] {IMS61SUB} )
[NO] {IMSATSDF}
[NO] {IMSATSLG}
[NO] {IMSDBDVL}
[NO] {IMSLCFMG}
[NO] {IMSPSBVL}
Specifies that the LU6.1 subpool name be used for the Automatic Terminal Signon (ATS) connection. The NO prefix disables this suboption and the LUNAME is used for the connection.
Default: NOIMS61SUB
Specifies that the facility DEFACID be used for the Automatic Terminal Signon. The NO prefix disables this suboption.
Default: NOIMSATSLG
Specifies that ATS signons are logged. The NO prefix disables this suboption.
Default: IMSDBDVL
Specifies that DBD validation is performed in IMS; the default. The NO prefix stops DBD validation.
Default: IMSNOIMSATSDF
Specifies that IMS transaction warning messages are displayed; the default. The NO prefix disables IMS warning messages.
Default: LCFMG
Specifies that PSB validation will occur in IMS; the default. The NO prefix stops PSB validation.
Default: IMSPSBVL
Be aware of the following when using the IMS control option.
