Previous Topic: Examples: ETROPTS control optionNext Topic: Installation Exit
EXIT—Installation Exit
Valid on z/OS and z/VM.
Use the EXIT control option to activate and deactivate the installation exit.
EXIT processing for resource checking requires the RDT attribute EXIT to be turned on for each resource class called the exit. By default the exit is not called for resources in the RDT. For information on the RDT attribute, see the Command Functions Guide.
All entry methods are accepted.
EXIT(ON|OFF)
ON
Causes CA Top Secret to call the installation exit module (TSSINSTX) at all exit control points.
OFF
(Default) Deactivates the installation exit.
