Previous Topic: Examples: DRC control optionNext Topic: Examples: DUFPGM control option
DUFPGM—Program to Use INSTDATA
Valid on z/OS.
Use the DUFPGM control option to:
If DUFPGM was changed using a TSS MODIFY command, the changes made remain in effect even if CA Top Secret is restarted. Most control options revert to their default settings, the exceptions are DUFPGM, JESNODE, and NJEUSR.
All entry methods are accepted.
DUFPGM(pgm1,...|RESET)
pgm1
The programs that can be specified.
Range: Up to 5
RESET
Clears the entire program list.
