Valid on z/OS and z/VM.
Use the DOWN control option to determine how jobs are initiated and passwords changed when the CA Top Secret address space is inactive. This control option must be set while CA Top Secret is active.
All entry methods are accepted.
DOWN(facility,action,facility,action,…facility,action)
Identifies the system facility being affected by the DOWN action. Valid values are:
Identifies the action that CA Top Secret performs when its address space is DOWN. Valid values are:
The default is DOWN(BW,SB,TW,OW).
The DOWN options are ignored if CA Top Secret is processing in global DORMANT mode.
This table shows how DOWN actions will affect various CA Top Secret processes.
PROCESS |
WAIT |
BYPASS |
FAIL |
NORMAL |
Initiation or Logon |
Initiations held and terminals locked |
Security Ignored |
Initiation Terminated |
TSO UADS Password Required |
Request for Password change |
Wait |
Wait |
Wait |
TSS command |
Failed |
Failed |
Failed |
Failed |
Data set in FAIL mode |
Failed |
BYPASS |
Failed |
Failed |
Submit a permitted ACID |
Job submitted without password |
TAPE(DEF) processing (volume level) |
Volume access denied |
BYPASS |
