Valid on z/OS and z/VM.
Use the DISPMASK control option to distinguish permissions which contain mask characters in a MASKABLE resource class.
When the DISPMASK(ON) control option is set, the LIST and WHOHAS commands:
ATTRIB=MASK
Generation of this line is not affected by DATA(TERSE) or by TSSCMDOPTION(TERSE) options. DISPMASK(OFF) is over ridden by DATA(ENHANCED) or TSSCMDOPTION(ENHANCED).
All entry methods are accepted.
DISPMASK(ON|OFF)
Permits the LIST and WHOHAS commands to display of the ATTRIB=MASK line for permissions with masked resource names.
(Default) Suppresses the display of the ATTRIB=MASK line.
