Valid on z/OS.
Use the DIAGTRAP control option to produce a diagnostic dump, based on limitations of ACID, JOBNAME, RESCLASS, and Detailed Reason Code. This is the CA Top Secret equivalent to O/S SLIP.
Use this control option only under the direction of CA Top Secret Support.
All entry methods are accepted.
DIAGTRAP(id,enable_swtich[,trap_type,acid,drc,resclass,job,matchlim]) DIATRAP(id,OFF) DIAGTRAP(id,DEL) DIAGTRAP(ALL,DEL)
Specify an ID. “All” is also a valid id as long as it is followed by “,Del” to indicate deleting all of the Diagtraps in the table. If no ID is specified while adding an entry, an error message is issued.
Range: 1 to 10
Enable or disable the given id. Valid values are:
Note: The enable and the id are the only entries required for turning an ID off.
Activates the trap in a particular location. This field must be entered and there is no default. A “)” can be entered any time after the trap to indicate defaults are to be taken for remaining fields. Valid traps are:
IF SF1 or SF2 is set, SFS is also set.
Important! Initially, when an entry is created, the trap_type is a required parameter in the DIAGTRAP syntax.
The ACID entered as a parameter to be matched for producing a dump.
Default: Any User id (*).
The Detailed Reason Code that must be produced to trigger the dump.
Default: Any violation (255).
Tests the resource class name.
Default: Any (*).
Specifies the job name of the job or started task to be monitored. The restrictions on acid, drc, resclass, and job are combined to trigger the DIAGTRAP: all conditions listed must be simultaneously present for the dump to be triggered.
Default: Any (*).
Sets the maximum number of dumps to be taken.
Range: 1 to 255
Default: 1
