Previous Topic: Examples: DB2FAC control optionNext Topic: DEBUG—Produce Dumps
Protect DB2 Subsystem Resources
The mode on the facility defined for the DB2 subsystem controls the protection of the DB2 subsystem resources. Specifying a non‑DORMANT mode for the facility associated with the DB2 subsystem protects its resources. A mode of DORMANT, or no DB2FAC control option specification for a DB2 subsystem, indicates that neither CA Top Secret for DB2 nor native DB2 will protect the resources in the DB2 subsystem. For information, see the Implementation:DB2 Guide
This example allows the protection of DB2 resources:
DB2FAC(DB2A=DB2PROD)
DB2FAC(DB2B=DB2PROD)
A specified mode of the following will allow protection of DB2 resources:
FACILITY(DB2PROD=MODE=FAIL)
The mode for the checks as well as other facility options are determined by the settings of the DB2PROD facility (LOG, ABEND/NOABEND). For example, if the user is logged onto TSO the MODE as well as all other facility control options are determined by the DB2PROD facility but only for DB2 resource checks. All other normal functions of TSO continue to occur under the TSO facility.
