Previous Topic: Example: CPFWAIT control optionNext Topic: Examples: DATE control option
DATE—Date Format
Valid on z/OS and z/VM.
Use the DATE control option to specify the format for dates displayed in listings. The DATE option accommodates various multinational date standards.
All entry methods are accepted.
DATE(yy/dd/mm)
YY
Year (90 . . .) For YY > 80, the year is assumed to be in the twentieth century. For YY < 80, the year is considered to be in the twenty‑first century.
DD
Day (01 . . . 31)
MM
Month (01 . . . 12)
Any character such as hyphen (‑), period (.), comma(,) can be used as a delimiter between the date fields. Some characters, such as comma(,) and blanks might require that the entire DATE control option be enclosed within quotes:
TSS MODIFY('DATE(MM DD YY)')
The choice of delimiters here affects the syntax of the UNTIL keyword during command administration. For example, if DATE('MM DD YY') were chosen then a command with the UNTIL keyword would need to be specified as follows:
TSS PERMIT(USER01) DSN(****.FILE)
                   UNTIL('05 01 94')
