Previous Topic: Example: CPFLOCAL Control OptionNext Topic: Examples: CPFNODE control option
CPFNODE—CPF Node Changes
Valid on z/OS and z/VM.
Use this control option to change the status and attributes of a CPF node after CA Top Secret has initialized and CPF is activated.
When a node is defined using the parmlib CPFNODE method rather than the NDT, the word STATIC appears in the display when a TSS MODI STATUS(CPF) command is issued. For example:
TSS966II CA Top Secret CPF Status
CPFNODE(XE58) Static Status(ACTIVE,NOSPOOL,...)
This control option uses the O/S and TSS MODIFY command entry methods.
CPFNODE(nodename=STOP|START|REFRESH)
STOP
Stop sending and receiving commands and passwords for the specified node. Currently queued messages are processed but no new messages are queued to this node.
While the specified node is stopped, entries for the node are not be written to the CPF Recovery File. Entries for the other CPF nodes continue to be written to the CPF Recovery File.
START
Activate a previously stopped node, or install and activate a new NDT defined node.
REFRESH
Modify the node attributes based on current NDT definitions. New attributes only affect commands and password changes not yet queued to the node. Recovery file records and in‑core queue entries are processed based on the attributes in effect prior to the refresh.
