Valid on z/VM.
Use the CPFLOCAL control option to identify the VTAM node name for CPF on this system and whether commands received from other CA Top Secret CPF nodes should be written to a journal file.
Note: CPFLOCAL nodename to match the CPFSYSID keyword on the NDT for identifying which CPF node definitions apply to this system. If this control option is not specified, the default will be the last 4 characters of the sysid for this system (see VMLOGID for more details).
This control option uses the Parameter File entry method.
CPFLOCAL(nodename(J|c)
Identifies the VTAM node ID for CPF on the system.
If specified, creates a journal file for CPF commands received from other CA Top Secret CPF systems.
Indicates a specific output class for CPF journal files.
Default: A
