Previous Topic: Example: CPF control optionNext Topic: Example: CPFFILE Control Option
CPFFILE—Identify CPF Recovery File
Valid on z/VM.
Use the CPFFILE control option to identify the OS data set name containing the CPF Recovery File. Use the data set must reside on the DASD volume or minidisk at virtual address x'600' of the server machine.
Note: See the Implementation Guide for considerations in the use of this control option and results of its omission.
This file cannot be shared with another system.
This control option uses the Parameter File entry method.
CPFFILE(dataset‑name)
datasetname
The OS data set name of the CPF Recovery File.
