Previous Topic: Examples: BACKUP control optionNext Topic: Example: BATCHCAN Control Option
BATCHCAN—Cancel Batch Job
Valid on z/VM.
Use the BATCHCAN control option to allow the CA Top Secret administrator s to cancel batch jobs while they are running prior to completion.
This control option uses the MODIFY entry method.
BATCHCAN(nnnn)
nnnn
Indicates the four-digit job number identified on the batch line of the output of a TSS MODIFY(STATUS) command. Use the job number shows in that display as J=nnnn.
