Previous Topic: The Online MODIFY CommandNext Topic: Hierarchy of Entry Methods
The Console MODIFY Command
CA Top Secret control options can be entered from a console using the O/S MODIFY command. The operator has the option of entering the command as part of the operator command syntax:
MODIFY TSS,(control option(suboption‑list))
Commands entered in this way must conform to operating system restrictions for operator console commands. Use of multiple commas, apostrophes, or parentheses can cause some control options to be rejected when issued as a console operator command. Only one control option should be modified in a single operator command, although multiple sub-options can be modified within that control option.
