Field Edit Formats
CA Telon-generated programs perform field edits:
Standard field edit routines and modules
CA Telon supplies a number of standard field edit routines. This appendix documents these routines, the parameters they pass, and the processing they perform.
Customized field edit routines
You can also code your customized edit routines for use at your installation.
Specifying a field edit
In the TDF, you can specify a field edit when you create a panel definition. The value of the FLDTYPE field, appearing on TDF panel field update screens, defines the data type of the application screen field (date, dollar, state code, and so on) and determines the corresponding field edit logic called to validate or format the field.
Standard Field Edit Routines
The following identify valid FLDTYPE values associated with standard field edit routines. In these tables, the data type processed Alpha is defined as PIC X for COBOL and CHAR for PL/I. The data type Numeric is defined as PIC 9 for COBOL and PIC BINARY, or FLOAT for PL/I.
CA Telon Output Edit Routines
FLDTYPE Value
Module Name
Type
Output Edit Action
CAR
OCAR
Alpha
Replaces unprintable characters with a period.
CART
OCART
Alpha
CJULIAN
OCJULIAN
OINTCJUL
Numeric
(INTDATE=U ) Converts a date stored in ccyyddd format to the U.S. format of mm/dd/ccyy or mmddccyy, depending on the output field length.
(INTDATE=I) Generates a call to OINTCJUL that converts a date stored in ccyyddd format to the international format of dd/mm/ccyy or ddmmccyy, depending on the output field length.
Note: INTDATE is a parameter in TLNIIS, and the default is U.
CDATE
OCDATE
Numeric
(INTDATE=U ) Converts a date stored in ccyymmdd format to the U.S. format of mm/dd/ccyy or mmddccyy, depending on the output field length.
(INTDATE=I) Generates a call to OINTCDT that converts a date stored in ccyymmdd format to the international format of dd/mm/ccyy or ddmmccyy, depending on the output field length.
DATE
ODATE
OINTLDT
Numeric
(INTDATE=U ) Converts a date stored in yymmdd format to the U.S. format of mm/dd/yy or mmddyy, depending on the output field length.
(INTDATE=I) Generates a call to OINTLDT that converts a date stored in yymmdd format to the international format of dd/mm/yy or ddmmyy, depending on the output field length.
FLNULL
OFLNULL
SQLNULL
If the field is null, spaces are moved to TPO-FLDNAME. Otherwise, the data is processed as the OFLOAT field edit does.
FLOAT
OFLOAT
OFORMAT
Numeric
Right-justifies a floating-point or signed-numeric field with an implied decimal point, using the smallest character representation possible with no loss of digits to the left of the (implied) decimal point.
HEX
OHEX
Alpha
Converts an EBCDIC character format item to hexadecimal.
HEXA
OHEXA
Alpha
HEXP
OHEXP
Alpha
HEXT
OHEXT
Alpha
JULIAN
OJULIAN
OINTJUL
Numeric
(INTDATE=U) Converts a date stored in yyddd format to the U.S. format of mm/dd/yy or mmddyy, depending on the output field length.
(INTDATE=I) Generates a call to OINTLJUL that converts a date stored in yyddd format to the international formats dd/mm/yy or ddmmyy, depending on the output field length.
NULL
ONULL
SQLNULL
If the field is null, spaces are moved to TPO-FLDNAME. Otherwise, the output field name is moved to TPO-FLDNAME.
NUMNULL
OFLNULL
ONUMNULL
If the field is null, spaces are moved to TPO-FLDNAME. Otherwise, TPO-FLDNAME is formatted using the output fieldname integers, and they are right-justified and blank-filled.
SSA
OSSA
Alpha
(DL/I processing only.) Parses an IMS SSA to determine the input SSA length. Returns both the SSA length and the SSA itself. Specified in the PIC field of the Update Output/Input/Outin Field screen.
VCHAR
OVCHAR
Variable character
Maps data from DBNAME hvname to TPO-fldname, where hvname is defined for the SQL VARCHAR column.
VNULL
OVNULL
SQLNULL
If the field is null, spaces are moved to TPO-FLDNAME. Otherwise, the data is mapped from DBNAME hvname to TPO-FLDNAME, where hvname is defined for SQL VARCHAR column.
CA Telon Input Edit Routines
FLDTYPE Name
Module Value
Type
Input Edit Action
CDATE
ICDATE
IINTCDT
Numeric
(Set INTDATE=U) Edits a date field for a valid U.S. format of mm/dd/ccyy, mm-dd-ccyy, or mmddccyy, depending on the input field length; then converts it to ccyymmdd format.
(INTDATE=I) Generates a call to IINTCDT that edits a date field for a valid International format of dd/mm/ccyy, dd-mm-ccyy, or ddmmccyy, depending on the input field length; then converts it to ccyymmdd format.
Note: INTDATE is a parameter in TLNIIS and the default is U.
CJULIAN
ICJULIAN
IINTCJUL
Numeric
(Set INTDATE=U) Edits a date field for a valid U.S. format of mm/dd/ccyy, mm-dd-ccyy, or mmddccyy, depending on the input field length; then converts it to ccyyddd format.
(INTDATE=I) Generates a call to IINTCJUL that edits a date field for a valid International format of dd/mm/ccyy, dd-mm-ccyy, or ddmmccyy, depending on the input field length; then converts it to ccyyddd format.
DATE
IDATE
IINTLDT
Numeric
(Set INTDATE=U) Edits a date field for a valid U.S. format of mm/dd/yy, mm-dd-yy or mmddyy, depending on the input field length; then converts it to yymmdd format.
(INTDATE=I) Generates a call to IINTLDT that edits a date field for a valid International format of dd/mm/yy, dd-mm-yy, or ddmmyy, depending on the input field length; then converts it to yymmdd format.
DOLLAR
IDOLLAR
IBDOL
ICURRNCY
Numeric
(INTDATE=U) Edits a field for a valid U.S. dollar and cents format (that is, two decimal places preceded by a period). This field does not accept negatives.
(INTDATE=I) Generates a call to ICURRNCY that edits a field for a valid International currency format (that is, two decimal places preceded by a comma).
FLNULL
IFLNULL
SQLNULL
If completely blank on input, FLNULL sets the null indicator. Otherwise, FLNULL edits a field for numeric format, allowing for a decimal point and a leading sign.
FLOAT
IFLOAT
Numeric
Edits a field for valid numeric format, allowing for a decimal point and leading sign.
FULLCAR
IFULLCAR
Alpha
Edits an input field to ensure there are no blanks in the field.
FULLNUM
IFULLNUM
Numeric
Edits a numeric field to ensure that all characters are numeric.
JULIAN
IJULIAN
Numeric
(INTDATE=U) Edits a date field for a valid U.S. format of mm/dd/yy, mm-dd-yy, or mmddyy, depending on the input field length; then converts it to yyddd format.
(INTDATE=I) Generates a call to IINTLJUL that edits a date field for a valid International format of dd/mm/yy, dd-mm-yy, or ddmmyy, depending on the input field length; then converts it to yyddd format.
LALPHA
ILALPHA
Alpha
Left-justifies a character field.
LNULL
ILNULL
SQLNULL
If blank on input, LNULL sets the null indicator. Otherwise, LNULL left-justifies a character field.
LVCHAR
ILVCHAR
Variable character
Left-justifies a character field (hvname is defined for SQL VARCHAR column).
LVNULL
ILVNULL
SQLNULL
If blank on input, LVNULL sets the null indicator. Otherwise, LVNULL left-justifies a variable-length character field into DBNAME hvname (hvname is defined for the SQL VARCHAR column).
NBALPHA
INBALPHA
Alpha
Edits a field to ensure there are no embedded blanks. NBALPHA allows leading and/or trailing blanks; FULLCAR does not.
NBNULL
INBNULL
SQLNULL
If blank on input, NBNULL sets the null indicator. Otherwise, NBNULL edits a field to ensure there are no embedded blanks.
NBVCHAR
INBVCHAR
Variable character
Edits a field to ensure there are no embedded blanks. (hvname is defined for SQL VARCHAR column.)
NBVNULL
INBVNULL
SQLNULL
If blank on input, NBVNULL sets the null indicator. Otherwise, NBVNULL edits a variable-length character field to ensure there are no embedded blanks.
NULL
INULL
SQLNULL
If blank on input, NULL sets the null indicator. Otherwise, NULL maps data from TPI-FLDNAME to DBNAME.
NUMERIC
INUMERIC
Numeric
Edits a field for valid numeric format, allowing for leading or trailing blanks (or both).
NUMNULL
INUMNULL
SQLNULL
If blank on input, NUMNULL sets the null indicator. Otherwise, NUMNULL edits a field for valid numeric format, allowing for leading and/or trailing spaces.
TATE
ISTATE
Alpha
Edits a field for valid two-character postal state code.
VCHAR
IVCHAR
Variable character
Maps data from TPO-fldname to DBNAME hvname (hvname is defined for SQL VARCHAR column).
VNULL
IVNULL
SQLNULL
If blank on input, VNULL sets the null indicator. Otherwise, VNULL maps data from TPI-fldname to DBNAME hvname (hvname is defined for the SQL VARCHAR column.)
Standard Field Edit Modules
The following table lists standard field edit modules provided by CA Telon and summarizes the edit function associated with each module.
Detailed documentation of each call module is provided after the table that includes:
See 1 for more information about edit processing.
Module Name
Edit Function
OCAR
Replace unprintable characters with periods
OCART
OCDATE
Format century date
OCJULIAN
Convert century Julian date to mm/dd/ccyy
ODATE
Format date
OFLNULL
Format a floating-point field that may be null
OFLOAT
OFORMAT
Reformat for output
OHEX
Convert character to hex
OHEXA
Convert characters to hex representation
OHEXP
OHEXT
OINTCDT
Format century date (international)
OINTCJUL
Format century Julian date (international)
OINTLDT
Format date (international)
OINTLJUL
Format Julian date (international)
OJULIAN
Convert Julian date to mm/dd/yy
ONULL
Format field based on null indicator
ONUMNULL
Format integer field based on null indicator
OSSA
Determine length of SSA
OVCHAR
Alphanumeric move from variable-length character field
OVNULL
IBDOL
Validate dollar entry
IBCURR
Validate international currency entry
ICURRNCY
IBNUM
Validate numeric entry
ICDATE
Check for valid century date
ICJULIAN
Convert century date to century Julian
IDATE
Check for valid date
IDOLLAR
Check for dollar/currency entry
IFLNULL
Validate floating-point entry and set null indicator
IFLOAT
Check for floating-point number
IFULLCAR
Check for blanks
IFORMAT
Validate and reformat on input
IFULLNUM
Check for all numeric characters
IHEX
Convert hex representation to hex characters
IHEXA
IINTCDT
Validate century date (international)
IINTCJUL
Convert century date to century Julian (international)
IINTLDT
Validate date (international)
IINTLJUL
IJULIAN
Convert date to Julian
ILALPHA
Left-justify a character field
ILNULL
Set null indicator and left-justify character field
ILVCHAR
Left-justify a variable-length character field
ILVNULL
Left-justify a variable-length length field and set null indicator
INBALPHA
Check for imbedded blanks
INBNULL
Check for imbedded blanks and set null indicator
INBVCHAR
INBVNULL
Check blanks for variable-length field and set null indicator
INULL
Set null indicator
INUMERIC
Check for valid integer
INUMNULL
Check for valid integer and set null indicator
ISTATE
Check for valid state code
IVCHAR
Alphanumeric move to variable-length character field
IVNULL
Set null indicator for variable-length field
OCAR
Function
Replaces unprintable characters with periods.
Parameters
Type
Name
Description
Input
TPO-fieldname-LTH
Length of the edited field. This must be between 1 and 256.
Input
output-fieldname
Field to be edited by this routine.
Output
TPO-fieldname
Edited output of the routine that is returned to the TPO buffer.
Edit processing
  1. Search the output field for unprintable characters.
  2. Translate unprintable characters to periods (X'4B').
OCART
Function
Replaces unprintable characters with periods. The difference between this field edit and IHEX is that this edit is passed the address of the field to be converted, rather than the value of the field itself.
Parameters
Type
Name
Description
Input
TPO-fieldname-LTH
Input
output-fieldname
Output
TPO-fieldname
Edit processing
  1. Search output-fieldname for unprintable characters.
OCDATE
Function
Format a date stored as ccyymmdd for output as either mm/dd/cc/yy (if TPO-datefield-LTH is 10) or mmddccyy (if the TPO-datefield-LTH is 8).
Note: If the INTDATE parameter in the TLNIIS macro is set to I, a call to OINTCDT is generated in place of a call to ODATE. For more information, refer to OINTCDT.
Parameters
Type
Name
Description
Input
WORKFLD-NUMERIC
Date to be edited. In a COBOL PIC S9(11)V9(7) field, the date is laid out as 000ccyymmdd0000000. In a PL/I PIC 10(9)V(4)9T field, it is laid out as 00ccyymmdd00000.
Input
TPO-datefield-LTH
Length of the output field.
Output
TPO-datefield
Edited date returned to the TPO buffer.
Edit processing
  1. Move ccyy in WORKFILED-NUMERIC to make the result mmddccyy.
  2. For 10-character output, insert the slashes.
  3. Move the edited form to the output field.
OCJULIAN
Function
Formats a date stored in ccyyddd for output as mm/dd/ccyy (if TPO-datefield-LTH is 10) or mmddccyy (if TPO-datefield-LTH is 8).
Note: If the INTDATE parameter in the TLNIIS macro is set to 'I,' a call to OINTCJUL is generated in place of a call to OCJULIAN. See OINTCJUL for more information.
Parameters
Type
Name
Description
Input
WORKFLD-NUMERIC
Date to be edited. In a COBOL PIC S9(11)V9(7) field, the date is laid out as 0000ccyyddd0000000. In a PL/I PIC (10)9V(4)9T field, it is laid out as 000ccyyddd00000.
Input
TPO-fieldname-LTH
Output
TPO-fieldname
Converted output of the routine that is returned to the TPO buffer.
Edit processing
  1. Convert ddd from the ccyyddd of WORKFLD-NUMERIC to mmdd.
    Note: If ddd is greater than 365 (366 for leap year), yy is adjusted one year for each additional 365 (366) days.
  2. If TPO-fieldname-LTH is 10, insert slashes (/) into the mmddccyy to create the mm/dd/ccyy format.
  3. Move the reformatted value to TPO-fieldname.
ODATE
Function
Formats a date stored as yymmdd for output as either mm/dd/yy (if TPO-datefield-LTH is 8) or mmddyy (if the TPO-datefield-LTH is 6).
Note: If the INTDATE parameter in the TLNIIS macro is set to 'I', a call to OINTLDT is generated in place of a call to ODATE. For more information, see 33.
Parameters
Type
Name
Description
Input
WORKFLD-NUMERIC
Date to be edited. In a COBOL PIC S9(11)V9(7) field, the date is laid out as 00000yymmdd0000000. In a PL/I (10)9V(4)9T field, it is laid out as 0000yymmdd00000.
Input
TPO-datefield-LTH
Output
TPO-datefield
Edit processing
  1. Move yy in WORKFLD-NUMERIC to make the result mmddyy.
  2. For eight-character output, insert the slashes.
OFLNULL
Function
Right-justifies a floating-point or signed-numeric field.
If the null indicator is set, the output field is set to spaces. The edit uses the minimum number of characters required to include all significant digits to the left of the implied decimal point. Then, given the output field length, it formats as many significant digits to the right of the decimal point as possible. Extra digits to the right of the decimal are truncated, not rounded.
The routine signifies an overflow condition (the output field is too small to contain the whole number) by filling the output field with all asterisks (*).
Parameters
Type
Name
Description
Input
WORKFLD-NUMERIC
Numeric value from the DBNAME field to be edited. In COBOL, PIC S9(11)V9(7); in PL/I, PIC (10)9V(7)9T.
Input
TPO-fieldname-LTH
Length of the output field. It must be 1 to 18 bytes for COBOL, 1 to 15 for PL/I.
Input
WK-fieldname-NV
Null indicator variable, set to -1 by SQL when the DBNAME is null.
Output
TPO-fieldname
Edited field returned to the TPO output buffer.
Edit processing
  1. Determine if the field is null by checking the null indicator.
  2. If the field is null, move spaces to the TPO buffer field. Otherwise, if WORKFLD-NUMERIC is negative, store a minus sign in the first position of TEMP-OUT-FIELD, a temporary, internal, alphanumeric work area.
  3. Bypass any leading zeros encountered before the implied decimal.
  4. Find any significant digits to the right of the decimal point and store them in TEMP-OUT-FIELD after any minus sign.
  5. If the significant positions after the implied decimal are all zeros, exit the edit processing. Otherwise, store a decimal point in TEMP-OUT-FIELD following the digits already there.
  6. Check to see if there are more significant characters in the TEMP-OUT-FIELD than specified by TPO-fieldname-LTH. If so, fill TPO-fieldname with all asterisks (*). Then exit the edit processing.
  7. Find all remaining digits after the decimal and up to the last group of all zeros. Store these digits in TEMP-OUT-FIELD after the decimal point.
  8. Right-justify the TEMP-OUT-FIELD value in TPO-fieldname and end the routine.
OFLOAT
Function
Right-justify a floating-point or signed-numeric field.
The edit uses the minimum number of characters required to include all significant digits to the left of the implied decimal point. Then, given the output field length, it formats as many significant digits right of the decimal point as possible. Extra digits right of the decimal are truncated, not rounded.
The routine signifies an overflow condition by filling the output field with all plus (+) or minus (-) signs, depending on the sign of the input value.
Parameters
Type
Name
Description
Input
WORKFLD-NUMERIC
Value to be edited. Before editing, the value is moved to this field from the DBNAME field to be output. In COBOL, PIC S9(11)V9(7); in PL/I, PIC (10)9V(4)9T.
Input
TPO-fieldname-LTH
Length of the edited field. It must be from one to 18 bytes.
Output
TPO-fieldname
Edit processing
  1. If WORKFLD-NUMERIC is negative, store a minus sign in the first position of TEMP-OUT-FIELD, a temporary, internal, alphanumeric work area.
  2. Bypass any leading zeros encountered before the implied decimal.
  3. Find any significant digits right of the decimal point and store them in TEMP-OUT-FIELD after any minus sign.
  4. If the significant positions after the implied decimal are all zeros, exit the edit processing. Otherwise, store a decimal point in TEMP-OUT-FIELD following the digits already there.
  5. Check to see if there are more significant characters in TEMP-OUT-FIELD than specified by TPO-fieldname-LTH. If so, fill TPO-fieldname with all plus (+) or all minus (-) signs, depending on the sign of the input field. Then exit the edit processing.
  6. Find all remaining digits after the decimal up to the last group of all zeros and store these in TEMP-OUT-FIELD after the decimal point.
  7. Right-justify TEMP-OUT-FIELD value in TPO-fieldname and end the routine.
OFORMAT
Function
Reformats output.
Specification for this special edit is made by entering the FORMAT command in the SPEC field on the Update Output/Input/Outin Field screen or the Update Batch Output Fields screen. See Update Output/Input/Outin Field for more information.
OHEX
Converts a character string to the hexadecimal equivalent for each character.
Parameters
Type
Name
Description
Input
output-fieldname
Field holding the characters to be converted to hex.
Input
TPO-fieldname-LTH
Length of the edited field. It can be from 2 to 256 bytes long.
Output
TPO-fieldname
Edited field returned to the TPO buffer.
Edit processing
  1. Determine the output field length.
  2. Use the assembly language TRANSLATE instruction and convert the input in eight-byte pieces.
  3. If fewer than eight characters remain, convert the last bytes individually.
OHEXA
Function
Converts a one- to four-character string to the hexadecimal equivalent for each character (for example, 'AB12' converts to 'C1C2F1F2'). This field edit is designed specifically for converting addresses.
Parameters
Type
Name
Description
Input
TPO-fieldname-LTH
Input
output-fieldname
Field to be converted by this routine.
Output
TPO-fieldname
Edit processing
  2. Use the assembler language TRANSLATE instruction to convert the output.
  3. If the output length is not equal to 8, the first byte of input is ignored, and bytes 2 through 4 are converted (with the assumption that the input is a 24-bit address). Otherwise, all four bytes are converted.
OHEXP
Function
Converts a one- to four-character string to the hexadecimal equivalent for each character (for example, 'AB12' converts to 'C1C2F1F2'). The difference between this field edit and OHEX is that this edit is passed the address of the field to be converted, rather than the value of the field itself.
Parameters
Type
Name
Description
Input
TPO-fieldname-LTH
Input
output-fieldname
Output
TPO-fieldname
Edit processing
  3. Move the output to TPO-fieldname.
OHEXT
Function
Parameters
Type
Name
Description
Input
TPO-fieldname-LTH
Input
output-fieldname
Output
TPO-fieldname
Edit processing
OINTCDT
Function
Reformats a date stored in ccyymmdd to dd/mm/ccyy (if TPO-datefield-LTH is 10) or to ddmmccyy (if the TPO-datefield-LTH is 8).
A call to this field is generated in either of the following cases:
Parameters
Type
Name
Description
Input
WORKFLD-NUMERIC
Date to be edited. In a COBOL PIC S9(11)V9(7) field, the date is laid out as 000ccyymmdd0000000. In a PL/I PIC (10)9V(4)9T field, it is laid out as 00ccyymmdd00000.
Input
TPO-datefield-LTH
Output
TPO-datefield
Edit processing
  2. Reformat the WORKFLD-NUMERIC date value from ccyymmdd to ddmmccyy. If TPO-datefield-LTH is 10, insert slashes (/) to produce dd/mm/ccyy.
  3. Move the reformatted value to TPO-datefield.
OINTCJUL
Function
Reformats a date stored in ccyyddd format to dd/mm/ccyy (if TPO-datefield-LTH is 10) or ddmmccyy (if TPO-datefield-LTH is 8).
A call to this field edit is generated in either of these cases:
Parameters
Type
Name
Description
Input
WORKFLD-NUMERIC
Input
TPO-datefield-LTH
Output
TPO-datefield
Edit processing
  2. Reformat the WORKFLD-NUMERIC date value from ccyyddd to ddmmccyy. If TPO-datefield-LTH is 10, insert slashes (/) to produce dd/mm/ccyy.
OINTLDT
Function
Reformats a date stored in yymmdd format to dd/mm/yy (if TPO-datefield-LTH is 8) or ddmmyy (if TPO-datefield-LTH is 6).
Parameters
Type
Name
Description
Input
WORKFLD-NUMERIC
Date to be edited. In a COBOL PIC S9(11)V9(7) field, the date is laid out as 00000yymmdd0000000. In a PL/I PIC(10)9V(4)9T field, the date is laid out as 0000yymmdd00000.
Input
TPO-datefield-LTH
Output
TPO-datefield
Edit processing
  2. Reformat the WORKFLD-NUMERIC date value from yymmdd to ddmmyy. If TPO-datefield-LTH is 8, insert slashes to produce dd/mm/yy.
OINTLJUL
Function
Reformat a date stored in yyddd format to dd/mm/yy (if the TPO-datefield-LTH is 8) or ddmmyy (if the TPO-datefield-LTH is 6).
Parameters
Type
Name
Description
Input
WORKFLD-NUMERIC
Date to be edited. In a COBOL PIC S9(11)V9(7) field, the date is laid out as 000000yyddd0000000. In a PL/I PIC (10)9V(4)9T field, the date is laid out as 00000yyddd00000.
Input
TPO-datefield-LTH
Output
TPO-datefield
Edit processing
  2. Reformat the WORKFLD-NUMERIC date value from yyddd to ddmmyy. If TPO-datefield-LTH is 8, insert slashes to produce dd/mm/yy.
OJULIAN
Function
Formats a date stored as yyddd for output as mm/dd/yy (if TPO-datefield-LTH is 8) or mmddyy (if TPO-datefield-LTH is 6).
Note: If the INTDATE parameter in the macro TLNIIS is set to 'I', a call to OINTLJUL is generated in place of a call to OJULIAN. For more information, see OINTLJUL.
Parameters
Type
Name
Description
Input
WORKFLD-NUMERIC
Date to be edited. It is the numeric value moved from the DBDNAME field. In a COBOL PIC S9(11)V9(7) field the date is last out as 000000yyddd0000000. In a PL/I as 00000yyddd00000.
Input
TPO-fieldname-LTH
Output
TPO-fieldname
Edit processing
  1. Convert ddd from the yyddd of WORKFLD-NUMERIC to mmdd.
    Note: If ddd is greater than 365 (366 for leap year), yy is adjusted up one year for each additional 365 (or 366) days.
  2. Insert slashes into the mmddyy to create the mm/dd/yy format.
ONULL
Function
Formats an output character field based on the null indicator.
Parameters
Type
Name
Description
Input
OUTPUT-fieldname
Field containing the characters to be output.
The length of OUTPUT-fieldname (DBNAME) must be at least as long as TPO-fieldname.
Input
TPO-fieldname-LTH
Input
WK-fieldname-NN
Null indicator variable, set to -1 by SQL when OUTPUT-fieldname is null.
Output
TPO-fieldname
Edit processing
  2. If the field is null, move spaces to TPO-fieldname. Otherwise, OUTPUT-fieldname is moved to TPO-fieldname.
ONUMNULL
Function
Right-justify an output integer to conform with a length specified by a PIC parameter on a Field statement.
If the null indicator is set, the output field is set to spaces. Otherwise, this edit right-justifies a numeric field.
The routine signifies an overflow condition by filling the output field with asterisks (*).
Parameters
Type
Name
Description
Input
WORKFLD-NUMERIC
Numeric value from the DBNAME field to be edited. In COBOL, PIC S9(11)V9(7); in PL/I, PIC(10)9V(4)9T.
Input
TPO-fieldname-LTH
Input
WK-fieldname-NN
Output
TPO-fieldname
Edit processing
  2. If the field is null, move spaces to TPO-FIELDNAME. Otherwise, the numeric value from the DBNAME field (WORKFLD-NUMERIC) is right-justified, blank-filled into TPO-fieldname.
OSSA
Function
Determines the length of an input SSA.
Parameters
Type
Name
Description
Input
segmentname-SSA
IMS SSA.
Output
TPO-ssaname
The SSA moved to the TPO output buffer.
Output
TPO-ssaname-LTH
Length of the SSA, to a maximum of 256.
Edit processing
  1. Search through the SSA to check for qualification.
  2. If a space is found during the search, process the SSA as qualified, then branch to compute the length below.
    If, instead, a left paren is found, process the SSA as unqualified. Search until an equal number of right and left parentheses is found, or until the maximum TPO-ssaname-LTH (256) is reached.
  3. Compute the length of the SSA and move the length to TPO-ssaname-LTH.
  4. Move the SSA to TPO-ssaname.
OVCHAR
Function
Returns a variable-length character field and length.
Parameters
Type
Name
Description
Input
output-fieldname
Variable-length character field containing the characters to be output.
Input
TPO-fieldname-LTH
Output
TPO-fieldname
Edit processing
  1. Determine the output field length (the lesser of the variable-length character field length and TPO-fieldname-LTH).
  2. Move the character portion of the variable-length character field to the output buffer (TPO-fieldname).
OVNULL
Function
Returns a variable-length character field and length by performing an alphanumeric move from a variable-length character field based on the null indicator.
If the null indicator is set, the output field is set to spaces. Otherwise, the character portion of the variable-length character field is moved to the output buffer.
Parameters
Type
Name
Description
Input
OUTPUT-fieldname
Input
TPO-fieldname-LTH
Input
WK-fieldname-NN
Null indicator variable, set to -1 by SQL when DBNAME is null.
Output
TPO-fieldname
Edit processing
  2. If the field is null, move spaces to TPO-fieldname. Otherwise, determine the output length (the lesser of the variable-length character field length and TPO-fieldname-LTH).
  3. Move the character portion of the variable-length character field to the output buffer.
IBDOL
Function
Checks input for valid dollar format, with a period (.) separating dollars and cents.
The difference between this field edit and IDOLLAR is that it allows larger numbers to be validated because the WORKFLD-NUMERIC-1 field in which the validated entry is returned is defined as PIC S9(16)V9(2) for COBOL, PIC (13)9V9T for PL/I.
Note: If the INTDATE parameter in the macro TLNIIS is set to 'I', a call to IBCURR is generated in place of a call to IBDOL. For more information, see IBCURR.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Value to be edited for valid dollar amount, from the TP input buffer.
Output
FIELD-EDIT-ERROR
Error status of the edit. Possible values are:
  • Spaces— No error was detected
  • G121— An error was detected during the edit
Output
WORKFLD-NUMERIC-1
Validated value, in format PIC S9(16)V9(2) for COBOL, PIC (13)9V9T for PL/I.
Edit processing
  1. Strip incoming TPI field of leading and trailing blanks.
  2. Test the antipenultimate position for a decimal point.
  3. Strip the decimal point and move the justified number to WORKFLD-NUMERIC-1.
  4. Zero-fill the value in WORKFLD-NUMERIC-1.
  5. Test WORKFLD-NUMERIC-1 for valid numeric value.
  6. Assign FIELD-EDIT-ERROR, based on outcome of decimal point placement test and numeric validation.
IBCURR
Function
Checks for valid international currency entry (that is, with a comma separating the last two digits of the numeric entry). The difference between this field edit and ICURRNCY is that it allows larger numbers to be validated because the WORKFLD-NUMERIC-1 field in which the validated entry is returned is defined as PIC S9(16)V9(2) for COBOL, PIC (13)9V9T for PL/I.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Value to be edited for valid currency amount, from the TP input buffer.
Output
FIELD-EDIT-ERROR
Output
WORKFLD-NUMERIC-1
Edit processing
  2. Test the antipenultimate position for a comma.
  3. Strip the comma and move the justified number to WORKFLD-NUMERIC.
IBNUM
Function
Checks a field for valid integer characteristics. The difference between this field edit and ICURRNCY is that it allows larger numbers to be validated because the WORKFLD-NUMERIC-1 field in which the validated entry is returned is defined as PIC 9(16)V9(2)T for COBOL, PIC (13)9V9T for PL/I.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Value to be edited for valid integer amount, from the TP input buffer.
Output
FIELD-EDIT-ERROR
Output
WORKFLD-NUMERIC-1
Validated value, in format PIC 9(16)V9(2) for COBOL, PIC (13)9V9T for PL/I.
Edit processing
  2. Justify the input entry and move it to WORKFLD-NUMERIC-1.
  3. Zero-fill the value in WORKFLD-NUMERIC-1.
  4. Test WORKFLD-NUMERIC-1 for valid numeric value.
  5. Assign FIELD-EDIT-ERROR, based on outcome of decimal point placement test and numeric validation.
ICDATE
Function
Checks input for valid date format, mm/dd/ccyy or mm-dd-ccyy (if TPO-datefield-LTH is 10) or mmddccyy (if TPO-datefield-Lth is 6), and stores it as ccyymmdd.
Note: If the INTDATE parameter in the TLNIIS macro is set to 'I,' a call to IINTCDT is generated in place of a call to IDATE. See 1.
Parameters
Type
Name
Description
Input
TPI-datefield-LTH
Length of the input field. It must be a halfword binary with a value of 8 or 10.
Input
TPI-datefield
Contents of the TP input buffer (the date to be edited).
Output
FIELD-EDIT-ERROR
  • ERR1— Length error
  • G123— An error was detected during processing of an eight-byte date
  • G130— An error occurred during processing of a ten-byte date
Output
WORKFLD-NUMERIC
Result of the edit, in a COBOL PIC S9(11)V9(7)9 field, the date is laid out as 000ccyymmdd0000000 for COBOL or 00ccyymmdd00000. The program moves this to the appropriate storage area after return from the edit routine.
Edit processing
  1. If the field length is ten bytes, check for valid delimiters. If invalid delimiters are found, exit with error code G130.
  2. Move the date to WORKFLD-NUMERIC and test for valid month, day, and year. If invalid, return appropriate error code. Otherwise, return edited date in WORKFLD-NUMERIC.
Note: The characters cc and yy are tested for only valid numeric characters. The characters dd and mm are edited for valid characters.
ICURRNCY
Function
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Output
FIELD-EDIT-ERROR
Output
WORKFLD-NUMERIC
Validated value, in format PIC S9(11)V9(7) for COBOL, PIC (10)9V(4)9T for PL/I.
Edit processing
  4. Zero-fill the value in WORKFLD-NUMERIC.
  5. Test WORKFLD-NUMERIC for valid numeric value.
IDATE
Function
Checks input for valid date format, mm/dd/yy or mm-dd-yy (if TPI-datefield-LTH is 8) or mmddyy (if TPI-datefield-LTH is 6), and stores it as yymmdd.
Note: If the INTDATE parameter in the macro TLNIIS is set to 'I,' a call to IINTLDT is generated in place of a call to IDATE. For more information, see IINTLDT.
Parameters
Type
Name
Description
Input
TPI-datefield-LTH
Length of the input field. It must be a halfword binary with a value of 6 or 8.
Input
TPI-datefield
Output
FIELD-EDIT-ERROR
  • Spaces— No error was detected.
  • G123—An error was detected during processing of an item in mmddyy or ddmmyy format.
  • G130— An error occurred during processing of an item in mm/dd/yy, dd/mm/yy, mm-dd-yy, or dd-mm-yy format.
Output
WORKFLD-NUMERIC
Result of the edit in a COBOL PIC S9(11)V9(7) field, the date is laid out as 00000yymmdd0000000. For PL/I PIC (10)9V(4)9T field, the date is laid out as or 0000yymmdd00000. The program moves this to the appropriate storage area after return from the edit routine.
Edit processing
  1. If the field length is eight, check for valid delimiters. If invalid delimiters are found, exit with error code G130.
  2. Move date to WORKFLD-NUMERIC and test for valid month, day, and year. If invalid, return appropriate error code. Otherwise, return edited date in WORKFLD-NUMERIC.
    Note: Yy is tested for only valid numeric characters. Dd and mm are edited for valid characters.
IDOLLAR
Function
Note: If the INTDATE parameter in the macro TLNIIS is set to 'I', a call to ICURRNCY is generated in place of a call to IDOLLAR. For more information, see ICURRNCY.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Contents of the TP input buffer (the dollar amount to be edited).
Output
FIELD-EDIT-ERROR
Output
WORKFLD-NUMERIC
Result of the edit in the COBOL PIC S9(11)V9(7) format or PL/I PIC (10)9V(4)9T format.
Edit processing
  2. Test the third from the last position for a valid decimal point (when INTDATE=U) or comma (when INTDATE=I).
  3. Strip the decimal point or comma and move the justified number to WORKFLD-NUMERIC.
  5. Test WORKFLD-NUMERIC for a valid numeric value.
IFLNULL
Function
Checks a field for a valid number. This allows for a leading sign and an optional decimal point.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Contents of the TP input buffer (the number to be edited).
Output
FIELD-EDIT-ERROR
  • NXXX— An error was detected during the edit
Output
WORKFLD-NUMERIC
Result of the edit in the COBOL S9(11)V9(7) format or PL/I PIC (10)9V(4)9T format.
Output
WK-fieldname-NN
Null indicator variable.
Edit processing
If the input field is blank, set the null indicator to -1. Otherwise, set the null indicator to 0 and:
  1. Skip leading blanks.
  2. Check to see if the next character is a plus (+) or minus (-) sign.
  3. Move all remaining characters, up to the decimal point, or a space, to a temporary work area DIGIT-GROUP.
  4. If DIGIT-GROUP has more than 11 digits in a COBOL program or more than 10 digits in a PL/I program, exit with error code NXXX. Otherwise, move the contents of DIGIT-GROUP to a second temporary work area WS-FIELD-NUM.
  5. If a decimal was found, place all numeric characters following the decimal point into DIGIT-GROUP.
  6. If the resulting DIGIT-GROUP has more than seven digits in a COBOL program or more than five digits in a PL/I program, exit with error code NXXX. Otherwise, move DIGIT-GROUP to WS-FIELD-NUM following the original digits and a decimal point.
  7. If the remaining unprocessed characters are blank, perform the following calculation to obtain the correct sign:
    WORKFLD-NUMERIC = 0 +│- WS-FIELD-NUM
    +│- is the sign stored as the first nonblank character from the input field. If no character is found, plus (+) is assumed.
  8. If any of the remaining unprocessed characters are not blanks, exit with error code NXXX.
IFLOAT
Function
Checks a field for a valid number. This allows for a leading sign and optional decimal point.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Output
FIELD-EDIT-ERROR
  • G122— An error was detected during the edit
Output
WORKFLD-NUMERIC
Edit processing
  3. Move all remaining characters, up to the decimal point, or a space, in a temporary work area DIGIT-GROUP.
  4. If DIGIT-GROUP has more than eleven digits in a COBOL program or more than nine digits in a PL/I program, exit with error code G122. Otherwise, move the contents of DIGIT-GROUP to a second temporary work area WS-FIELD-NUM.
  5. If a decimal was found, place all the following numeric characters in DIGIT-GROUP.
  6. If there are more than seven digits in the resulting DIGIT-GROUP value, exit with error code G122. Otherwise, move DIGIT-GROUP to WS-FIELD-NUM following the original digits and a decimal point.
    WORKFLD-NUMERIC = 0 {+│-} ES-FIELD-NUM.
    If any of the remaining unprocessed characters are not blanks, exit with error code G122.
IFULLCAR
Function
Verify that there are no blanks in an input field. The difference between IFULLCAR and INBALPHA is that IFULLCAR allows no blanks at all. INBALPHA allows leading and trailing blanks.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Contents of the TP input buffer (the character field being checked for blanks).
Output
FIELD-EDIT-ERROR
Output
WORKFLD-ALPHA
Edited field. It is a 256-byte alphanumeric field.
Edit processing
  1. Scan for blanks.
  2. Return an error code of G122 if any blanks are found. Otherwise, move the field to WORKFLD-ALPHA and exit.
IFORMAT
Function
Reformats input.
Specification for this special edit is made by entering the FORMAT command in the SPEC field on the Update Output/Input/Outin Field screen.
See Update Output/Input/Outin Field or Update Batch Output Fields for more information.
IFULLNUM
Verify that all input characters in the field are numeric.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Contents of the TP input buffer (the number being checked).
Output
FIELD-EDIT-ERROR
  • G124— An error was detected during the edit
Output
WORKFLD-NUMERIC
Edited field in the COBOL S9(11)V9(7) format or the PL/I PIC (10)9V(4)9T format.
Edit processing
  1. Test all positions for valid numeric characters.
  2. If any non-numeric characters are found, exit with error code G124.
  3. Right-justify and zero-fill the input value and move it to WORKFLD-NUMERIC.
IHEX
Function
Converts a hex-character string to the hexadecimal equivalent for each pair of hex-character representations (for example, 'C1F2' converts to 'A1').
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Field to be converted by this routine, from the TP input buffer.
Output
FIELD-EDIT-ERROR
Output
WORKFLD-ALPHA
Converted value.
Edit processing
  1. Determine the length of the input field.
  2. Use the assembler language TRANSLATE instruction to convert the output from hex-representation to its character equivalent.
  3. Assign FIELD-EDIT-ERROR.
IHEXA
Function
Converts a hex-character string of one to eight bytes to the hexadecimal equivalent for each pair of hex-character representations (for example, 'C1F2' converts to 'A1'). This field edit is designed specifically for converting addresses.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Output
FIELD-EDIT-ERROR
Output
WORKFLD-ALPHA
Converted value.
Edit processing
  2. Use the assembly language TRANSLATE instruction to convert the output from hex-representation to hexadecimal.
  3. Right-justify the input into the full-word output field.
  4. Assign FIELD-EDIT-ERROR.
IINTCDT
Function
Validates a date entered as dd/mm/ccyy or dd-mm-ccyy (if TPI-datefield-LTH is 10) and stores it in ccyymmdd format.
Parameters
Type
Name
Description
Input
TPI-datefield-LTH
Length of the input field. It must be eight or ten bytes.
Input
TPI-datefield
Field to be validated by this routine, from the TP input buffer.
Output
FIELD-EDIT-ERROR
  • G123— An error was detected during validation of an eight-byte date
  • G130— An error was detected during validation of a ten-byte date
Output
WORKFLD-NUMERIC
Converted date. In a COBOL PIC S9 (11) V9 (7) field, the date is laid out as 000ccyymmdd0000000. In a PL/I PIC (10)9V (4)9T field, the date is laid out as 00ccyymmdd00000.
Edit processing
  1. Determine the input field length.
  2. If 10, check for valid delimiters ('/' or '-'). If invalid delimiters are found, set FIELD-EDIT-ERROR to G130.
  3. Move date to WORKFLD-NUMERIC and test for valid day, month, century, and year.
  4. If invalid, set FIELD-EDIT-ERROR to the appropriate error code. Otherwise, return edited date in WORKFLD-NUMERIC.
    Note: Cc and yy are tested only for valid numeric characters. Dd and mm are edited for both numeric and valid month-day combinations.
IINTCJUL
Function
Validates a date entered as dd/mm/ccyy or dd-mm-ccyy (if TPI-datefield-LTH is 10) and stores it in ccyyddd format.
Parameters
Type
Name
Description
Input
TPI-datefield-LTH
Input
TPI-datefield
Output
FIELD-EDIT-ERROR
Output
WORKFLD-NUMERIC
Converted date. In a COBOL PIC S9(11)V9(7) field, the date is laid out as 0000ccyyddd0000000. In a PL/I PIC (10)9V(4)9T field, the date is laid out as 000ccyyddd00000.
Edit processing
  2. If 10, check for valid delimiters ('/' or '-'). If invalid delimiters are found, set FIELD-EDIT-ERROR to ERR1.
  3. Test for valid day, month, and year. If invalid, set FIELD-EDIT-ERROR to the ERR1 error code. Otherwise, convert the edited date to ccyyddd and move it to WORKFLD-NUMERIC.
ICJULIAN
Function
Checks input for a valid date format, mm/dd/ccyy or mmd-dd-ccyy (if TPI-datefield-LTH is 10) or mmddccyy (if TPI-datefield-LTH is 8).
Note: If the INTDATE parameter in TLNIIS is set to 'I,' a call to IINTCJUL is generated in place of a call to ICJULIAN. See IINTCJUL later in this appendix.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Field to be validated by this routine, from the TP input buffer (the date to be edited).
Output
FIELD-EDIT-ERROR
Output
WORKFLD-NUMERIC
Julian date in a COBOL PIC S9(11)V9(7) format laid out as 0000ccyyddd0000000 or a PL/I PIC (10)9V(4)9T format laid out as 000ccyyddd00000 in PL/I.
Edit processing
  1. If the length is 10, test for valid delimiters ('/' or '-'). Exit with error code ERR1 if they are not found.
  2. Test for valid day, month, and year (cc is checked simply for valid numeric value). Exit with error code ERR1 if anyone is invalid.
  3. Convert the date to Julian format (ccyyddd) and move the results to WORKFLD-NUMERIC.
IINTLDT
Function
Validates a date entered as dd/mm/yy or dd-mm-yy (if TPI-datefield-LTH is 8), or ddmmyy (if TPI-datefield-LTH is 6), and stores it in yymmdd format
Parameters
Type
Name
Description
Input
TPI-datefield-LTH
Length of the input field. It must be six or eight bytes.
Input
TPI-datefield
Output
FIELD-EDIT-ERROR
  • G123— An error was detected during validation of a six-byte date
  • G130— An error was detected during validation of an eight-byte date
Output
WORKFLD-NUMERIC
Converted date. In a COBOL PIC S9(11)V9(7) field, the date is laid out as 00000yymmdd0000000. In a PL/I PIC (10)9V(4)9T field, the date is laid out as 0000yymmdd00000.
Edit processing
  2. If 8, check for valid delimiters ('/' or '-'). If invalid delimiters are found, set FIELD-EDIT-ERROR to G130.
  3. Move date to WORKFLD-NUMERIC and test for valid day, month, and year.
    Note: Yy is tested only for valid numeric characters. Dd and mm are edited for both numeric and valid month-day combinations.
IINTLJUL
Function
Validates a date entered as dd/mm/yy or dd-mm-yy (if TPI-datefield-LTH is 8) or ddmmyy (if TPI-datefield-LTH is 6), and store it in yyddd format.
Parameters
Type
Name
Description
Input
TPI-datefield-LTH
Input
TPI-datefield
Output
FIELD-EDIT-ERROR
  • ERR1— An error was detected during validation.
Output
WORKFLD-NUMERIC
Converted date. In a COBOL PIC S9(11)V9(7) field, the date is laid out as 000000yyddd0000000. In a PL/I PIC (10)9V(4)9T field, the date is laid out as 00000yyddd00000.
Edit processing
  2. If 8, check for valid delimiters ('/' or '-'). If invalid delimiters are found, set FIELD-EDIT-ERROR to ERR1.
  3. Test for valid day, month, and year. If invalid, set FIELD-EDIT-ERROR to ERR1. Otherwise, convert edited date to yyddd and move it to WORKFLD-NUMERIC.
IJULIAN
Function
Checks input for a valid date format, mm/dd/yy or mm-dd-yy (if TPI-datefield-LTH is 8) or mmddyy (if TPI-datefield-LTH is 6).
Note: If the INTDATE parameter in the macro TLNIIS is set to 'I', a call to IINTLJUL is generated in place of a call to IJULIAN. For more information, see IINTLJUL.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Length of the input field. This must be 6 or 8.
Input
TPI-fieldname
Output
FIELD-EDIT-ERROR
Output
WORKFLD-NUMERIC
Returns the Julian date in a COBOL PIC S9(11)V9(7) field, the date is laid out as 000000yyddd0000000 in a PL/I PIC (10)9V(4)9T field, the date is laid out as 00000yyddd00000.
Edit processing
  1. If the field length is 8, test for valid delimiters (/ or -). Exit with error code ERR1 if they are not found.
  2. Test for valid day, month, and year. (Yy is checked simply for valid numeric value.) Exit with error code ERR1 if any one is invalid.
  3. Convert the date to Julian format of yyddd and move the results to WORKFLD-NUMERIC.
ILALPHA
Function
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Length of the input fields.
Input
TPI-fieldname
Contents of the TP input buffer (the field to be left-justified).
Output
WORKFLD-ALPHA
Edited field as a 256-byte alphanumeric field.
Edit processing
  1. Start on left and search for the first nonblank character.
  2. Compute length of remaining field.
  3. Use the result to left-justify the result in WORKFLD-ALPHA.
ILNULL
Function
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Output
FIELD-EDIT-ERROR
Output
WORKFLD-ALPHA
Result of the edit as a 256-byte alphanumeric field.
Output
WK-fieldname-NN
Edit processing
  1. Start on the left and search for the first nonblank character.
  3. Use the result to left-justify the remaining characters into WORKFLD-ALPHA.
ILVCHAR
Function
Left-justifies a variable-length character field.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Contents of the TP input buffer (the variable length field to be left-justified).
Output
WORKFLD-VCHAR
Edited field as a 256-byte alphanumeric variable-length field.
Edit processing
  1. Start on left and search for the first nonblank variable-length character.
  2. Search for the last nonblank variable-length character.
  3. Compute length of remaining field.
  4. Use the result to left-justify the result in WORKFLD-VCHAR.
  5. Move the length to the length part of WORKFLD-VCHAR.
ILVNULL
Function
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Contents of the TP input buffer (the variable-length field to be left-justified).
Output
FIELD-EDIT-ERROR
Output
WORKFLD-VCHAR
Result of the edit as a 256-byte variable-length alphanumeric field.
Output
WK-fieldname-NN
Edit processing
If the input field is blank, set the null indicator to -1. Otherwise, set the null indicator to 0, and:
  2. Search for the last nonblank character.
  4. Use the result to left-justify the remaining characters into WORKFLD-VCHAR.
  5. Move the length of the remaining field to the length portion of the WORKFLD-VCHAR.
INBALPHA
Function
Checks for imbedded blanks. INBALPHA differs from IFULLCAR because it allows leading and trailing blanks. IFULLCAR allows neither.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Contents of the TP input buffer (the character field being checked for imbedded blanks).
Output
FIELD-EDIT-ERROR
Output
WORKFLD-ALPHA
Edited field in a 256-byte alphanumeric field.
Edit processing
  1. Search for the first nonblank character.
  2. Search for the next nonblank character or end-of-field.
  3. If end-of-field is reached before the next nonblank, move the input field to WORKFLD-ALPHA and exit without an error code.
  4. If a blank is found, make sure all remaining characters are blank. If they are, move the input field to WORKFLD-ALPHA and exit without an error code. If another nonblank is found, exit with error code G122.
INBNULL
Function
Checks for imbedded blanks. This edit allows for leading and trailing blanks.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Contents of the TP input buffer (the field being checked for imbedded blanks).
Output
FIELD-EDIT-ERROR
  • N122— An error was detected during the edit
Output
WORKFLD-ALPHA
Output
WK-fieldname-NN
Edit processing
  3. If end-of-field is reached before the next nonblank character, move the input field to WORKFLD-ALPHA and exit without an error code.
  4. If a blank is found, make sure all remaining characters are blank. If they are, move the input field to WORKFLD-ALPHA and exit without an error code. If another nonblank character is found, exit with error code N122.
INBVCHAR
Function
Checks for imbedded blanks. This edit allows leading and trailing blanks.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Contents of the TP input buffer (the variable-length character field being checked for imbedded blanks).
Output
FIELD-EDIT-ERROR
Output
WORKFLD-VCHAR
Edited field in a 256-byte alphanumeric variable-length field.
Edit processing
  3. If end-of-field is reached before the next nonblank, move the input field to WORKFLD-VCHAR and exit without an error code.
  4. If a blank is found, make sure all remaining variable-length characters are blank. If they are, move the input field to the character part of WORKFLD-VCHAR, move the length to the length part of WORKFLD-VCHAR and exit without an error code. If another nonblank is found, exit with error code G122.
INBVNULL
Function
Checks for imbedded blanks in a variable-length character field. This edit allows for leading and trailing blanks.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Contents of the TP input buffer (the variable-length field being checked for imbedded blanks).
Output
FIELD-EDIT-ERROR
Output
WORKFLD-VCHAR
Output
WK-fieldname-NN
Edit processing
  3. If end-of-field is reached before the next nonblank character, move the input field to the character portion of WORKFLD-VCHAR, move the length to the length portion of WORKFLD-VCHAR, and exit without an error code.
  4. If a blank is found, make sure all remaining variable-length characters are blank. If they are, move the input field to the character portion of the WORKFLD-VCHAR, move the length to the length portion of WORKFLD-VCHAR, and exit without an error code. If another nonblank character is found, exit with error code N122.
INULL
Function
Checks for a completely blank field.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Contents of the TP input buffer (the field to be checked).
Output
FIELD-EDIT-ERROR
Output
WORKFLD-ALPHA
Returns the result of the edit as a 256-byte alphanumeric field.
Output
WK-fieldname-NN
Edit processing
If the input field is blank, set the null indicator to -1. Otherwise, set the null indicator to 0, and move the contents of TPI-fieldname to WORKFLD-ALPHA.
INUMERIC
Function
Checks for a valid integer. This field edit allows for leading and trailing blanks, but not imbedded blanks and non-numeric characters.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Output
FIELD-EDIT-ERROR
Output
WORKFLD-NUMERIC
Edited field in the COBOL S9(11)V9(7) format or the PL/I (10)9V(4)9T format.
Edit processing
  1. Search for the first nonblank character. Make sure it is numeric.
  2. Search for the earlier of the next nonblank or the end-of-field. Make sure there are no imbedded blanks and that all characters are numeric.
  3. If no imbedded blanks or non-numeric characters are found, right-justify and zero-fill the field in WORKFLD-NUMERIC and exit. Otherwise, exit with error code G122.
INUMNULL
Function
Checks for a valid integer. This edit allows leading and trailing blanks, but not imbedded blanks and non-numeric characters.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Contents of the TP input buffer (the field being edited).
Output
FIELD-EDIT-ERROR
Output
WORKFLD-NUMERIC
Result of the edit in the COBOL S9(11)V9(7) format or PL/I (10)9V(4)9T format.
Output
WK-fieldname-NN
Edit processing
  2. Search for the earlier of the next nonblank character or end-of-field. Make sure there are no imbedded blanks and that all characters are numeric.
  3. If no imbedded blanks or non-numeric characters are found, right-justify and zero-fill the field in WORKFLD-NUMERIC, and exit the edit. Otherwise, exit the edit with an error code of N122.
ISTATE
Function
Verify that a valid two-character postal state code is entered.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Length of the input field. It must always be 2.
Input
TPI-fieldname
Contents of the TP input buffer (the state code to be checked).
Output
FIELD-EDIT-ERROR
  • G133— An error was detected during the edit
Output
WORKFLD-ALPHA
Returns the edited field in a 256-byte alphanumeric field.
Edit processing
  1. Move TPI-fieldname to WORKFLD-ALPHA.
  2. Verify the contents of WORKFLD-ALPHA against a state-code table that includes the 50 states, the District of Columbia, and Puerto Rico.
  3. If there is a match, exit with no error. Otherwise, exit with error code G133.
IVCHAR
Function
Moves a variable-length character field.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Contents of the TP input buffer (the variable-length character field to be moved).
Output
WORKFLD-VCHAR
Edited field in a 256-byte (maximum) alphanumeric variable-length character field and the length of the variable-length character field.
Edit processing
  1. Search for the last nonblank character.
  2. Determine remaining length of field.
  3. Move the input field to the character part of WORKFLD-VCHAR.
  4. Move the length to the length part of WORKFLD-VCHAR.
IVNULL
Function
Sets a null indicator based on the contents of a variable-length character field. This edit can be used to check for a blank input field.
Parameters
Type
Name
Description
Input
TPI-fieldname-LTH
Input
TPI-fieldname
Contents of the TP input buffer (the variable-length field to be checked).
Output
FIELD-EDIT-ERROR
Output
WORKFLD-VCHAR
Output
WK-fieldname-NN
Edit processing
  2. Determine the remaining length of field.
  3. Move the input field to the character portion of WORKFLD-VCHAR.
  4. Move the length to the length portion of WORKFLD-VCHAR.
Calls to Field Edit Modules
Automatic calls to input or output edits, whether CA Telon- or user-supplied, always pass parameters in the order shown in the examples below.
Output edit processing
The following code shows an automatic call to an output edit, the CA Telon-supplied DATE output edit routine. DAY is the screen field to receive the edited output.
COBOL
CALL 'ODATE   '  USING TPO-DAY
    TPO-DAY-LTH,
    WORKFLD-NUMERIC.
PL/I
CALL ODATE (TPO_DAY,
    TPO_DAY_LTH,
    WORKFLD_NUMERIC);
Input edit processing
The following code shows the automatic call to an input edit, the CA Telon-supplied DATE input edit routine. DAY is the screen field holding the input to be edited. The edited data is returned to WORKFLD-NUMERIC.
COBOL
CALL 'IDATE   '  USING FIELD-EDIT-ERROR  TPI-DAY-LTH
    TPI-DAY
    WORKFLD-NUMERIC.
PL/I
CALL  IDATE (FIELD_EDIT_ERROR,
    TPI_DAY_LTH,
    TPI_DAY,
    WORKFLD_NUMERIC);
Copyright © 2010 CA. All rights reserved. Email CA about this topic
