During dump capture, CA SymDump System communicates with CA SYSVIEW (or Server) to collect information about the dumping address space. This information is stored in the reports data set, the smaller of the two data sets created for each dump. When the dump is loaded, the reports are displayed in the dump tree in the Formatted Reports folder, grouped by the type of information they provide and listed alphabetically within each group by report title.
Using the OPTLIB, you can customize your dump captures to include any of the reports available from CA SYSVIEW. Most of these reports are listed in the appendix Report Categories which lists the reports by group with a brief description of each. For a detailed description of the contents of these reports, including field-by-field explanations, refer to the CA SYSVIEW (or Server) User Guide.
In addition to these reports, CA SymDump System offers the following additional reports:
By default, each of these reports also appears in the Favorites folder. These reports are only available to CA SymDump System users and are documented in this appendix.
This section contains the following topics:
The CICS Task Storage Summary is generated for CICS dumps when the #CICSAXS command appears in the OPTLIB member during dump capture. This report summarizes all of the storage allocated for each active task at the time of the dump. The summary shows the storage address and length, the subpool name and DSA type, and the first sixteen bytes of data at the storage address. Additionally, if the leading or trailing crumple zone has been overlaid, a “storage violation” indicator is displayed (in the StgV column) to show this.
This is a sample Task Storage Summary:
CA SymDump System V9.1 --------- Task Storage Summary ----------- Line 1 of 14 Command ===> Scroll ===> CSR ------------------------------------------------------------------------------- CICS Task Storage Summary ------------------------------------------------------------------------- Lvl 3 TaskNo Address Length DSANm StgV Subpool +8 +C +10 + 000004 00046000 00000440 CDSA M0000004 00B46EC4 C6C8C5C9 E4E24040 4 000005 00049000 00000440 CDSA M0000005 00B46EC4 C6C8C5C9 E4E24040 4 000007 1CC85000 000005D0 ECDSA C0000007 00B46EC4 C6C8C5C9 E4E24040 4 000019 1C436840 00000620 ECDSA C0000019 06086EE9 D5C1C3F2 00000000 0 000019 1C436440 00000400 ECDSA C0000019 00006EE9 D5C1C3F1 C7F0F0F1 9 000019 1C436000 00000440 ECDSA C0000019 00B46EC4 C6C8C5C9 E4E24040 4 000018 1C438000 00000440 ECDSA C0000018 00B46EC4 C6C8C5C9 E4E24040 4 000028 001C4000 00000440 UDSA B0000028 00B46EC4 C6C8C5C9 E4E24040 4 000028 1CD20330 000000A0 EUDSA U0000028 0000021C 0000025C 0000028C F 000028 1CD20300 00000030 EUDSA U0000028 6EE3E2C9 D6C14040 00100000 C 000028 1CD20000 00000300 EUDSA U0000028 000002E8 00000000 00000000 0 000028 1CC84000 000001B0 ECDSA C0000028 FFFFFFFF FFFFFFFF FFFFFFFF F 000039 001C0440 00000380 UDSA StgV B0000039 00000367 00000000 00000000 0 000039 001C0000 00000440 UDSA B0000039 00B46EC4 C6C8C5C9 E4E24040 4
The CICS Kernel Error Summary is generated for CICS dumps when the #CICSKER command appears in the OPTLIB member during dump capture. This report summarizes the last CICS kernel errors that occurred in the CICS region. The summary shows the system and CICS error code, the program and the offset where the error occurred, the pointer to the DFHKERRD control block, and the date and time of the error.
When this report is generated, the DFHKERRD address for each kernel error is also listed in the CICS Control Blocks folder under the subfolder Kernel Errors. These control blocks are also auto-mapped for your convenience.
The following is a sample CICS Kernel Error Summary:
CA SymDump System V9.1 ------- Kernel Errors ------------------- Line 1 of 13 Command ===> Scroll ===> CSR ------------------------------------------------------------------------------- CICS Kernel Error Summary ------------------------------------------------------------------------- Lvl 3 Error Module Offset Type DFHKERRD Error# Date 0C7/AKEA ASMDEMO 019C Program Check 0C61E110 000013 2009/03/21 ---/ASRA DFHSRP 03C2 Abend Percolate 0C61DF68 000012 2009/03/20 0C7/AKEA COBDEMO 1B8C Program Check 0C61DDC0 000011 2009/03/20 ---/ASRA DFHSRP 03C2 Abend Percolate 0C61DC18 000010 2009/03/20 0C7/AKEA ASMDEMO 019C Program Check 0C61DA70 000009 2009/03/20 ---/ASRA DFHSRP 03C2 Abend Percolate 0C61D8C8 000008 2009/03/20 0C7/AKEA COBDEMO 1B8C Program Check 0C61D720 000007 2009/03/20 ---/ASRA DFHSRP 03C2 Abend Percolate 0C61D578 000006 2009/03/20 0C7/AKEA ASMDEMO 019C Program Check 0C61D3D0 000005 2009/03/20 ---/ASRA DFHSRP 03C2 Abend Percolate 0C61D228 000004 2009/03/20 0C7/AKEA PL1DEMO 1A74 Program Check 0C61D080 000003 2009/03/20 ---/ASRA DFHSRP 03C2 Abend Percolate 0C61CED8 000002 2009/03/20 0C7/AKEA COBDEMO 1B8C Program Check 0C61CD30 000001 2009/03/20 -------------------------------------------------------------------------------
The CICS Message Help report is generated for CICS dumps when the #CICSMSG command appears in the OPTLIB member during dump capture. You can also create this report dynamically from the dump viewer using the CMSG command. This report describes the reason for the CICS message, dump code or transaction abend code and in many cases recommends an action.
To view this report, the CADVCMSG DD must allocate the DFHCMACD member of the SDFHMSGS library for CICS when the viewer is started.
The following is a sample CICS Message Help report:
CA SymDump System V9.1 --------- CICS Message Help -------------- Line 1 of 43 Command ===> Scroll ===> CSR ------------------------------------------------------------------------------- CICS Message Help for DFHSM0103 ------------------------------------------------------------------------- Lvl 2 DFHSM0103 APPLID A STORAGE VIOLATION (CODE X'CODE' ) HAS BEEN DETECTED BY THE STORAGE VIOLATION TRAP. TRAP IS NOW INACTIVE. EXPLANATION: A storage violation has been detected by the storage violation trap, which may be enabled via the CHKSTSK or the CHKSTRM system initialization parameters or via the CSFE transaction. The code X' code ' is the exception trace point ID which uniquely identifies the type of storage violation detected. SYSTEM ACTION: CICS disables the storage violation trap. An exception entry (X' code ' in the message) is made in the trace table. A system dump is taken, unless you have specifically suppressed dumps in the dump table. F1=HELP F2=SPLIT F3=END F4=DUMP F5=RFIND F6=MAP F7=UP F8=DOWN F9=SWAP F10=LEFT F11=RIGHT F12=RETRIEVE
The CICS Summary report is generated for CICS dumps when the #CICSSUM command appears in the OPTLIB member during dump capture. This report identifies the CICS system data areas, the currently dispatched task, and displays all of the storage areas owned by each of the active tasks.
When this report is generated, each of the task-level control blocks is added to the CICS Control Blocks folder under the subfolder Task Control Areas. These control blocks are also auto-mapped for your convenience.
The following is a sample CICS Summary report:
CA SymDump System V9.1 --------- CICS Summary ------------------ Line 1 of 148 Command ===> Scroll ===> CSR ------------------------------------------------------------------------------- CICS Summary Report for A04IC9N6 ------------------------------------------------------------------------- Lvl 3 ******** CICS Areas ********* +0 +4 +8 +C CSA at 0004DE20 for 0000204 bytes: 00000248 0000D0A0 1C39B0E8 9C7CD7FE . COPFL at 0004D648 for 0000588 bytes: 00000000 00000000 1C494A00 00000000 . SIT at 9C0C16B0 for 0000850 bytes: E702E753 00000000 08500400 00000000 X CWA at 000C1000 for 0000400 bytes: 00000000 00000000 00000000 00000000 . TCT at 00051D80 for 0000600 bytes: 0006973C 00069810 00051D8C 8004DE20 . Current TCA at 0005A680 for task #0039 (STGV). **** Active Task Summary **** --------------------------------------------------- | Task #0039 Tran STGV Term G001 User CICSUSER | | Date 07/22/2009 at 10.11.07 | --------------------------------------------------- F1=HELP F2=SPLIT F3=END F4=DUMP F5=RFIND F6=MAP F7=UP F8=DOWN F9=SWAP F10=LEFT F11=RIGHT F12=RETRIEVE
The CICS Trace Dialog is available for CICS dumps when the #CICSTRA command appears in the OPTLIB member during dump capture. You can also create this report dynamically from the dump viewer using the CTRACE command. Use this interactive dialog to view the CICS internal trace table, formatted by the CICS trace formatter.
To view this report, the CADVCICS DD must allocate a concatenation of the SDFHLOAD and SDFHLINK libraries for your CICS release when the viewer is started. If you use multiple CICS releases, you can concatenate the libraries for multiple releases.
The CICS Trace dialog enables you to view the internal trace in any of the formats provided by the CICS trace formatter program. This includes abbreviated, short, and full trace formats. The dialog also provides filters that let you to customize the view by selecting only the entries that interest you, and line commands that allow you to zoom in for full details on individual entries.
When the dialog is first appears, the unfiltered trace table is displayed in the abbreviated format, and the filters are disabled, as shown here:
CA SymDump System V9.1 --------- Trace ------------------------ Line 1 of 6600 Command ===> Scroll ===> CSR ------------------------------------------------------------------------------- CICS - AUXILIARY TRACE FROM 01/04/01 - APPLID A04IC9N6 6,600 ENTRIES VIEW ABBREV FILTERS OFF SHOW ON COLUMNS "OR" OFF TASK TCB DM ID MOD DATA . * * * * * * ------------------------------------------------------------------------- Lvl 3 . =00001= 00053 QR DS 0002 DSAT ENTRY CHANGE_PRIORITY . =00002= 00053 QR DS 0003 DSAT EXIT CHANGE_PRIORITY/OK . =00003= 00053 QR AP F001 XCP EXIT WAIT . =00004= 00053 QR AP 00E1 EIP EXIT SUSPEND OK . =00005= 00053 QR AP 00E1 EIP ENTRY SUSPEND . =00006= 00053 QR AP F000 XCP ENTRY WAIT . =00007= 00053 QR DS 0002 DSAT ENTRY CHANGE_PRIORITY . =00008= 00053 QR DS 0003 DSAT EXIT CHANGE_PRIORITY/OK . =00009= 00053 QR AP F001 XCP EXIT WAIT . =00010= 00053 QR AP 00E1 EIP EXIT SUSPEND OK . =00011= 00053 QR AP 00E1 EIP ENTRY SUSPEND . =00012= 00053 QR AP F000 XCP ENTRY WAIT . =00013= 00053 QR DS 0002 DSAT ENTRY CHANGE_PRIORITY . =00014= 00053 QR DS 0003 DSAT EXIT CHANGE_PRIORITY/OK
The control fields are located in the information area at the top of the dialog. These fields are described here:
Switches the view for the entire report. Specify either ABBREV (for abbreviated), SHORT or FULL. If you have altered the view for an individual entry, that entry is not affected by this value until it is reset.
Specify OFF to display the entire unfiltered trace table, or ON to display only those entries matching the filter criteria.
Specify ON to display the filters, and OFF to suppress them. This does not affect the trace entries displayed.
When filters are active (FILTERS ON), this value determines how the filtering criteria are evaluated. When OFF is specified, only those trace entries that match an entire row of your filtering criteria display. When ON is specified, any entry that matches at least one value from each column displays.
Each filter entry consists of the following six values:
The task ID of the CICS task from which the entry originated.
The CICS TCB ID for the TCB from which the entry originated.
The two-character ID of the domain which wrote the entry.
The four-digit trace point identifier used to differentiate between the various trace entries that originate from the same CICS domain.
The CICS module from which the trace entry originated, excluding the leading DFH characters.
Any value from the data portion of the trace entry, including data that is not displaying in the currently selected view. In other words, you can use a data filter that matches data only displayed in the full format, even if your current view is abbreviated.
You can add as many filtering rows as can fit on your screen, but the display is not scrollable. To add or remove a row, use the following line commands in the command column at the far left side of the filter entries:
Deletes a row.
Inserts a new blank row.
Replicates a row.
You can specify a wild card value ("*") in any column to indicate that any value should match. A row of filtering values containing all wild cards will match every CICS trace entry. You cannot specify a prefix value by appending a wild card character to the end of a value, such as "D*". Wild card values can only be specified as "*" to indicate "match any".
A blank entry in any column will not match any values. Blanking out one column does not cause that column to be ignored, it causes the column to not match any trace entries. Therefore, when Columns "OR" is OFF, blanking out a column serves to disable the entire row.
Each trace entry appears in the format defined by the VIEW control field, unless that entry was reformatted using one of the following line commands:
Display the entry using the abbreviated view.
Display the entry using the full view.
Reset any overriding view for this entry.
Display the entry using the short view.
From within the CICS Trace dialog, type HELP on the command line and press ENTER to display this information online. From any other display within the dump viewer, type HELP AUXTRACE.
The Abend Summary report is generated when the #SUMMARY command appears in the OPTLIB member during dump capture. This report displays information about the abending or dumping task, including the completion code, TCB address, and the registers and PSW at the time of the error.
When this report is produced, the following built-in equates are also created when the dump is loaded:
The following is a sample Abend Summary report:
CA SymDump System V9.1 --------- Abend Summary ------------------ Line 1 of 19 Command ===> Scroll ===> CSR ------------------------------------------------------------------------------- Job: MIKED530 System: XAE1 Asid: 00B3 ------------------------------------------------------------------------- Lvl 3 Abend Summary for SM0102 DFHSM0102 A04IC9N6 A storage violation (code X'030B') has been detected by modu PIDS/565501800 LVLS/530 MS/DFHSM0102 RIDS/DFHSMGF PTFS/UQ52744 PRCS/0000030B PSW at time of error: 078D2000 9BFEF5F0 DFHSIP +AC970 TCB address: 007CF850 Registers at time of error: Reg 0 = 000000B8 PSA+B8 Reg 8 = 1C0B67D8 E-PVT Reg 1 = 1CC435A0 E-PVT Reg 9 = 1CC4362C E-PVT Reg 2 = 1C0B67D8 E-PVT Reg 10 = 1CC4362C E-PVT Reg 3 = 9BFEDDA8 DFHSIP+EDDA8 Reg 11 = 1CC42C87 E-PVT Reg 4 = 1CC434A0 E-PVT Reg 12 = 0005A680 PVT Reg 5 = 1BFEEDA7 DFHSIP+EEDA7 Reg 13 = 1CC434A0 E-PVT Reg 6 = 1BFEFDA6 DFHSIP+EFDA6 Reg 14 = 007D2828 JSTCB-3E8 Reg 7 = 1CC42904 E-PVT Reg 15 = 00000000 PSA ------------------------------------------------------------------------------- F1=HELP F2=SPLIT F3=END F4=DUMP F5=RFIND F6=MAP F7=UP F8=DOWN F9=SWAP F10=LEFT F11=RIGHT F12=RETRIEVE
