The Load Program
The CA Repository Exchange for Assembler uses a procedure called DBXSCNC to load the output from the Assembler scanner. You can find this procedure in the CCP$JCL (DBXSCNC) data set. DBXSCNC inserts and updates instances as needed to create program object definitions for the scanned Assembler program.
Before you run the load procedure, you need to customize the DBXSCNC JCL to:
Copyright © 2009 CA. All rights reserved. Email CA about this topic
