Previous Topic: Working with Your Custom ReportsNext Topic: Add Report
Create and Upload BIRT Report Definitions to CA Process Automation Services
You can create new BIRT reports and upload them to the Orchestrator so that they can be executed and viewed directly in the Reports tab. You can also allow other users to view such reports. To create a BIRT report, download the BIRT RCP Designer from the BIRT Official website at http://download.eclipse.org/birt/downloads.
The BIRT RCP Designer can be used to edit an existing report or to create new report design files. See the BIRT RCP Designer documentation.
BIRT reports can be uploaded to a CA Process Automation Orchestrator and viewed later.
Follow these steps to upload a new or modified design file
  1. Log in to CA Process Automation.
  2. Click Reports tab.
  3. Select the Add New from the reports tool bar.
  4. Provide the report name, description, and indicate whether the report is viewable by other users.
  5. Click Browse and navigate to the report design file on your system and click Open.You can only upload reports that have the .rptdesign extension.
  6. Click Save.
Follow these steps to replace a design file
  1. Log in to the CA Process Automation web interface.
  2. Click the Report tab.
    The Reports pane opens.
  3. Click the report that you want to replace, then click Replace.
  4. Provide the path of the Report file that you want to upload to an Orchestrator, then click Submit.
Note: A production user can upload or replace reports only in private reports. However, a content administrator can upload or replace predefined reports.
