Previous Topic: Dequeue a Pending RequestNext Topic: About the Start Request Form
Abort a Running Request
A request in the Running state can be aborted.
To abort a running request, right-click the instance on the request pane of Start Request pane, and click the Abort command.
The task state then changes to Failed, and processing of the process instance is ended. The Start Time column shows the time when the process control module starts processing the instance of the process. The End Time column shows the time when the processing is aborted.
Given the right permissions, you can open an aborted process instance to view the processing status for icons in the process.
