Previous Topic: Activate SchedulesNext Topic: Deactivate a Schedule Using Process Watch
Activate a Schedule Using Process Watch
Use the following procedure to activate a schedule object using Process Watch. To use Process Watch to activate an agenda, there must be a Process Watch object for the agenda.
  1. Log in to the CA Process Automation web interface.
  2. Select Process Watch from the Operations tab.
  3. Select the schedule object that you want to activate form the respective folders displayed in the left pane.
  4. Right-click the schedule object and select Activate.
    The schedule on the Orchestrator in whose repository the schedule resides is activated.
  5. Right-click and select Properties for the schedule object in the library browser to view the Orchestrator on which the schedule object is activated.
