Previous Topic: DatasetsNext Topic: Working with Resources
Edit Parameters in Datasets
Dataset palette in the Operations tab lets a content administrator view and edit the datasets defined in CA Process Automation. You cannot use the Dataset palette on the Operations tab to add a dataset.
  1. Log in to CA Process Automation as a content administrator.
  2. Click Operations tab, and select Dataset palette.
  3. Make a selection from the expandable list of defined datasets objects.
    The right hand pane displays the parameters name, and value that are defined for the dataset objects.
  4. Click the row and then select View Expression to get expression for that variable to use in process definitions.
  5. Click the Value field of a parameter, and edit the parameter value and click Save.
  6. To edit the indexed field in an array, right click a parameter to select Add Indexed value. A new indexed field value is added to the array.
To delete a parameter, right-click it, select Delete Indexed value, and confirm the deletion.
Note: A user can only view the datasets defined in CA Process Automation dataset objects.
